Question about Cameras
Battery needs to b charged - Cameras
Posted by msaltruist10 on
john smith
    New Friend:
The camera uses most power when you take a picture.
If there's not enough then the camera will shut down, or not operate.
Your manual says charge the battery before first use or when the low battery indicator shows.
You can't start fretting over the camera misbehaving if you don't follow the manual.
Don't forget to format the card. It will work for a while without but then you'll find you have problems viewing and downloading your images. You can even lose them all.
Don't worry about draining the battery before re-charging it...that only applies to Nicad batteries and something called "the memory effect". You have a Lithium battery that can be charged at any state with no problem.
__________
Cegonsoft
Posted on Jul 25, 2011
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
Samsung battery wont charge need to reset it
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 15, 2013 | Samsung Galaxy Tab Tablet PC
The charger works but it does not full my battery it always says that low battery though i charge it for an hour..
Try charging it up overnight.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 30, 2012 | Creative Labs Zen Micro MP3 Player
My laptop will not work on the battery and i need to keep it plugged in although the battery say 100% charged, why
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 24, 2011 | HP Computers & Internet
When my acer aspire 5734z laptop is plugged in the charger indicator flashes and the battery indicator shows blue.it stays at 0% and says plugged in,not charging.if i unplug the charger it shuts down. need...
Feb 11, 2011 | Computers & Internet
My wii remopte won't charge. The battery dies and when I try to charge it, it only charges for about 30 seconds then says that it's charged and it's obviously not. (please help, thanks)
Your battery or charger is probably toast - this is the exact same thing my remotes did, so I went to Amazon and bought new batteries and charger - now they work fine. The batteries are designed for so many charges then they die.If, like me, you park your remotes on the charger stand when not in use that counts as charging whether or not the batteries need it so it would be better to lay your remotes next to your Wii or charger base if they don't need charging. Also - charging the batteries when they don't need it can shorten the battery's life, depending on the specific type of battery you bought. Before buying a replacement battery, find out the specific type of battery and whether or not it requires charging before getting low or needs to run out before charging. You can get this info from the seller of the battery. Hope this helps!!
Dec 28, 2010 | Video Game Consoles & Games
Will not fully recharge battery
Ifthe battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 03, 2010 | Cell Phones
Battery will not charge.
Either the battery is bad, or the battery charging circuit in the laptop is bad. To be able to judge, you will need to replace the battery is a one that is known to be working fine & see if it will be charged.
If it charges fine, then your battery needs to be replaced with a new one. If the test battery did not charge as well, then the battery charging circuit in the laptop is defective & needs to be repaired.
Jul 19, 2009 | Acer Aspire One PC Notebook
Cameras Logo
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
