Question about Sony Playstation 3 (PS3) Console
Went to turn on system one day it told me it wasn't shut down properly, so i shut it off, later turned it back on and it goes on and then shuts right off and it wont eject my disc, what is wrong with it please help
Posted by stacymertens on
Richard Page
    Master:
  • 325 Answers
Try a reset, power on your PS3 but hold in the power button till the second beep and release.
Posted on Jul 25, 2011
Can we turn the heat off 2-3 rooms with this brivis wombat 92 gas heating system - heating just the parts of the house we choose.
You could freeze water pipes if bathrooms are connected to those rooms - on a cold winter day (depending where you are). All gas appliances should have a shutoff valve. Shutting that off may screw up the main controller - it won't get the proper signal that the flame started ok.
Aug 24, 2014 | Heating & Cooling
High pitched squeel from the hard drive and then shuts down.
restart the computer HOLD the keys CTRL +F11 OR F12 depend of your mark, model, and go restore to the factory default, and fix it.
Passs the antivirus+antimalware very IMPORTANT!
God bless you
Jul 20, 2013 | Acer Computers & Internet
Lost picture
do tou have another display you could use? if it does it with that display too then you have eliminated that its a problem with your display. You could also disconnect and reconnect all connection to the display and make sure they are secure
Jan 29, 2013 | HP Pavilion Computers & Internet
Kodak playfull will not turn on
probably the camcorder wasn't meant to be underwater or a underwater camcorder can only function properly during a certain depth you go in the water.. but if you go over the limit of the depth you went underwater it would shut down and not come back to function properly.
Aug 02, 2012 | Kodak PLAYFULL Ze1 Camcorder
Empty radiator and reservoir but not overheating
a load of codswallop
for a temp gauge to work , it has to have coolant around it
when there is no coolant the gauge will not get to overheat
most likely it would start because the motor has been cooked
what the people were try to say is that if the coolant temp sensor is working and it gets too hot the engine light comes on and it goes into limp mode which still allows you to get off the road to check things out
Mar 30, 2017 | 2003 Ford Explorer
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
I have a used Dell Inspiron 8200, it has not been cleaned out but it worked fine when I got it, I ran a System Restore and used it until about four days ago when the computer froze. I shut it off, (did not...
Severe corruption. Since you can no longer boot in any way in it it's going to be extremely hard to fix it. Better just reinstall Windows from scratch. Use the recovery cd that should have come with the laptop. If you don't have it then just use a disk borrowed from a friend and the key on the label.
Jun 14, 2011 | Dell Inspiron 8200 Notebook
Just got my transmission replaced, now it SEEMS like my alternator is out. when i got my car back, the battery light was on and flickering. one day i went to the store, when i cane back out and started my...
HAVE YOUR ALTERNATOR TSTED AT A PARTS STORE
YOU SHOULD GET BATTERY TESTED ALSO
WHEN VOLTAGE GOES DOWN IT WILL SHUT OFF COMPUTER
CAUSING CAR ENGINE TO SHUT DOWN SOMETIME JUST SITTING THE BATTERY COULD
RECUPERATE A BIT TO LET ENGINE START AGAIN BUT ALL POINTS TO ALTERNATOR
Apr 19, 2011 | 2000 Mercury Cougar
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
