Question about Archos Internet Media Tablet MP3 Player
After firmware update on new HDD my Archos 5 IMT model 6500 don't boot and endless display start screen...
Posted by latchezar_d on
5 Related Answers
Anonymous
SOURCE: archos 404 recovery code 2
i have an archos 404 the problem is that my archos show me the recovery code 4 to repair or format the disk so when ever i repair and format the disk the problem is solved. so please help me regarding this.
Posted on Oct 23, 2008
Anonymous
  • 5 Answers
SOURCE: Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
Anonymous
SOURCE: Archos 5 won't boot up
im having the same problem,people say reset it and put it into recovery mode (it tells you in the quick start guide) or that didnt work for me so im trying charging it up fully.  also mine makes a noise while trying to turn on, are you having this problem to?
Posted on Aug 04, 2009
andy1958
Andy Borofsky
  • 14 Answers
SOURCE: where is the reset button on the archos 5 60 GB IMT
The reset button is on the bottom of the unit. You will see two holes right next to each other it is the one that is close to the center of the case, you will need a paper clip to reset the unit. In case my description is unclear it is to the right of the connectors on the bottom of the unit.
Posted on Aug 24, 2009
Anonymous
SOURCE: Archos 5 constantly rebooting after reset
Heyy i have the same problem! Can u let me kno if u ever found a solution? thanx
Posted on Dec 24, 2009
Cant download a flashplayer for archos5
Is it archos 5 or archos 5 IT ?
For archos 5 IT is already upgrade to 2.2 as far as I know.
For archos 5 I don't think there is one and with archos they don't bother doing anymore upgrades for older models.
Found this for the archos 5 IT.
http://www.youtube.com/watch?v=GzgfCTp6--k
Aug 18, 2012 | Archos Internet Media Tablet MP3 Player
I'm new in the line of using Archos. I was trying to register it when it indicate a new update available. I did ACCEPT to download the update. Now my Archos 5 is not coming up. Can you please help with...
Hi,to solve your problem please follow the instructions .
Hold down the volume button and the power button for several seconds the ARCHOS goes into a restore type mode.
connect the archos to your computer with the usb cable .next copy and paste the downlaoded firmware .aos file onto the aarchos device .
your archos device will be detected as a mobile device in windows explorer.double-click on the device to see its "internal hard driver.open this internal hard driver icon and you will see the various archos folder inside..paste the update file into this area but be careful not to paste it into any of folders there.
the device will recognize the new update file and invite you to install it.Follow the on-screen instructions.
To download the firmware navigate to this link click HERE
To the firmware ..select your product ..and then click on Download Archos 5 Internet Tablet OS v 2.0.38 (92054Kb) .
Save it to your desktop .
Dec 26, 2010 | Vacuums
Cant watch videos on web on archos 605 wifi
You should be on firmware version 2.1.04 (WMDRMPD:10.1) If connected to your computeer or on WiFi then :- Main Screen Menu Settings Firmware + Plugins and click on.... Online Firmware Update This version of the firmware does allow some videos. Unfortunately if the videos come up with blank screen with a red F9 in the middle this signifies a version of FlashPlayer not yet supported. We just have to wait and see if Archos are still going to support the 605 with more firmware updates or if their hands fare too ull with the new Archos 5 Android.
Apr 02, 2010 | Archos 605 WiFi Digital Media Player
My archos 5 IMT 160 gb has a blank screen. It looks like is charged. I makes noise while is starting up, but the screen is blank. I* charged for over 10 hours.
Screen is blank?
Do you mean you won't see anything at all like the signup colorful screen that says "ARCHOS Entertaining your way" ?
If your battery is full charged (did  the CHG LED green light blink when it finished charging?), and you have a blank screen, do you have a serious problem indeed. If your unit is under warranty your best and only way is contact Archos.
If when you turn it on, it takes you to the Recovery screen (white screen, usually says Code 101) then try to Format the HDD, download the latest firmware from www.archos.com for your unit, copy it from your PC to the Archos, let it finish the process wth the power supply connected, and once it's done the unit should be back working fine with the latest fimware.
But if you definetely do not see anything but a blank screen when you turn it off, your problem is more serious than a simple firmware upgrade, and you need to contact Archos tech support.
Mar 08, 2010 | Archos Internet Media Tablet MP3 Player
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
When switched on goes to a HDD Recovery option but when options tried a Media Failed message is received and 604 returns to the original screen
I have the same problem and I do not know how to fix it. The problem with mine is that I have replace the hard drive with a new one so it does not have the original files. Does it connect through the USB connection and does the computer detect it?
May 20, 2009 | Archos 604 Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 Recovery code 108
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
Feb 18, 2008 | Archos 605 WiFi Digital Media Player
I need help
Once you format your device it wipes out most of the information on your archos including the Firmware. You need to connect your archos to your computer and download the firmware from the main Archos site. Copy the firmware to your device. Diconnect the device from your computer using the safe disconnect feature. When your archos restarts it will either automatically recognize the new firmware and update itself or it will bring up the repair screen. One version of this screen has the options "do nothing", "repair device", or "format". Choose repair device. This will start the update sequence.
The other version of the white screen will say your system is damaged and show the options "done" or "repair device". Again select repair device and the update sequence will start. You may have to do this more than once in a repair session.
I have had to do this to my own device several times so save a copy of the firmware and your plugins on your computer to download back to the device if you have to do this again. Hopefully the next Archos update will take care of these annoying issues
I hope this helps!
Jan 24, 2008 | Archos 605 WiFi Digital Media Player
Archos Internet Media Tablet MP3 Player Logo
137 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
