Question about Proton MM2701VT 27" TV
I'm trying to turn on my Panasonic t.v. It stays on for about 5 seconds then turns off by itself. There is also a flashing red light where it says power on the front of the t.v. I'm not able to turn the t.v. back on until I unplug it completely from the power supply and plug it back in....then it happens all over again. I bought this t.v. brand new 5 months ago....please help.
Posted by xxxdancinque on
mark pascual
    Scholar:
    New Friend:
  • 68 Answers
First try to check for the power supply of the TV. the power supply of the TV is located on the place where the main plug of the monitor is connected, check for busted or defective fuse by using a multimeter a defective fuse has no reading on a multimeter. the red line flashes because of a short circuit on the power supply. check for a shorted transistors, diode or maybe a loose connection on the power supply section.may this one help you..
Posted on Jul 25, 2011
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Proton MM2701VT 27" TV Logo
64 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
