Energy Speakers ESW-10 Subwoofer Logo
Posted on Jul 25, 2011
ESW-10 Subwoofer stopped working. Getting power to it but no power output. Speaker is fine. No light coming on in front of cabinet either.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
728
Points
Did you check the fuse (pop out cassette just at the power input point)?
Energy ESW-V10 - blue led always "ON" but woofer won/t turn "On", no matter if switch is in "auto-On" or "ON" .
If the blue LED on your Energy ESW-V10 subwoofer is always on but the woofer won't turn on regardless of the switch position, it's possible that there is an issue with the amplifier or power supply. Try checking the power cord and making sure it's plugged in securely. If that doesn't work, you may need to have the subwoofer professionally repaired or replaced.
Energy ESW-M6 Powered Subwoofer. How to open an Energy esw-m6 please?
Question edited for clarity, full 'make model (what it is)'.
Question moved form Computers to one of the Energy categories.
Ask the company direct. They probably aren't meant to be opened.
https://www.energy-speakers.com/products/subwoofers/?sku=ESW-M6
Esw-c10 subwoofer hums and dont work
if you short a sub it will hum try connecting it to a working speaker (no amplifier) if you have access to rear of sub check for wire only needs to be the size of a hair arcing out the speaker, i have a sub that does that on only one output (left rear) its actually the stereo causing it to hum..
JBL JRX118SP POWERED SUB. Getting power and signal light flashes when theres a signal. Just no sound??? Speaker/coil looks fine..
There's a 8-pin ic located right at the side of output devices & power supply filter caps, that is a common issue with JRX active subwoofers, hope it helps.
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
1helpful
Would putting an EVM10DLX into a set of Yamaha BR-10s be a recommended upgrade? Worth the cost?
It is VERY RARE for such a change to be beneficial. The cabinets and speakers are finely tuned to work together and the originals are usually just as good performers as anything you can replace them with. If you want a subwoofer you need to get a larger cabinet and preferably a larger speaker. A ten inch speaker for subwoofer use would require a closely engineered cabinet. Best to go to a single powered 15 inch subwoofer (one designed as subwoofer) to run alongside your BR-10's.
16helpful
2answers
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
The subwoofer is only putting out about 10% of it's capacity
if the speaker is actually receiving signal and has sound, the next question is if the sub is self amplified or not. if it is check the amp in it. if not then check your unit to make sure the bass is not turned down and that the correct surround setting are there. there is also possibility that the show or item your listening too isn't outputting correct channels.
Energy S8.3 Subwoofer
I have the exact same problem with my S8.3 that I purchased a few months ago. It's just the blue LED that doesn't light up, otherwise it seems to output bass and the volume control works. Any suggestions?
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Top Energy Speakers Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
kishnakant...
kishnakant...
Are you an Energy Speakers Audio Player and Recorder Expert? Answer questions, earn points and help others
