Nike Zoom Skyposite Anthracite Size=95M for Men Logo
Question about Nike Zoom Skyposite Anthracite Size=95M for Men
My foot lenght is 26cm so what shoe buy? with 26,5 cm insole or 27cm. Shoe for street not running.
Posted by rozki on
Jim Pattison
    Master:
  • 1,004 Answers
I would recommend 26.5 at least for street wear. Check the fit and see how your foot fits on the insole
Posted on May 14, 2014
3answers
How do i glue my shoes
a glue called shoe goop ive had luck with
3answers
My sole has a hole in it. How do I repair it?
Is its not FS6 gas cushioned then its sometimes time to repair with rubber repair of BISON.
Can the insoles be replaced after they collapse
Absolutely. better quality shoe stores have replacement insoles that you can select.
2answers
How do you change battery in Carter's kids light up shoes
There is a battery in the insole. Lift the insole and the battery will be in the heel
1helpful
I have a pair of brand new ecco shoes. Finally convinced my grade 12 daughter to pair the price and buy well made shoes. They are a purple leather lace up shoes. They make airy sounds with ever step....
I've had this problem with my daughter's shoes, and her foot is very narrow. I cut down some generic-brand Dr. Scholl's-type insoles (available at grocery and drugstores) and that did the trick.
1. Get the appropriate sized insoles, and lay the right show on the right insole, and the left shoe on the left insole. Trace them with a pen.
2. Cut out the insole, cutting slightly inside the lines-- the inside of the shoe is smaller than the outside.
3. Work the insoles inside the shoe. Use your fingers to feel around the edges to see where you need to trim them to fit.
4. If it's too long, don't trim all the length off the toe, or all the length off the heel... you'll mess up where the arch curves.
Good luck! I hope it works for you.
Install spd on this shoe, does the insole have to ripped out?
Does the shoe have the mounting plate already inside the holes? If it does screw the the cleat in as usual. If it doesnt, remove the insole to install it.
Mar 06, 2011 • Lake CX190
2helpful
7answers
Where can convert european shoe sizes to american?
Here you may find a convertion table for shoe sizes.http://www.dancesport.uk.com/shoes/conchart.htm
Top Nike Clothing Accessories Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nike Clothing Accessory Expert? Answer questions, earn points and help others
