GE APH10AA Air Conditioner Logo
Posted on Jul 24, 2011
I have a GE aew10amg1 that is not regulating the temp and is resetting the temp control to 86 and turning itself off. when i adjust the temp back the numbers auto adjust back.
3 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jul 11, 2009
SOURCE: climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Mar 17, 2010
SOURCE: My ge artica model number pss25ngma the refer part
check the evaporator fan; listen to see if it is running check the baffles between the freezer and, the refrigerator box for air flow. Check the control knob to see if it is turning the cold control shaft. If these are not the problem: replace the cold control
Anonymous
  • 116 Answers
  • Posted on Mar 26, 2011
SOURCE: I have a stainless GE profile PSS26SGPASS side by
HI has the temp held steady at 28? And do you notice if the fan in running in the freezer if you open the door do you hear a fan running, if you do not, then the problem is a bad control board located in the rear of the refigerator behind an small access panel this control board runs about 175-200.00 to buy.
Sean
1helpful
GE Side By Side Temp Won't Reset
If you have tried resetting the temperature settings to the default values and the temperature remains at -9°F in the fridge and 37°F in the freezer, there could be an issue with the fridge's cooling system. Here are some additional things to check:
1. Make sure the fridge is receiving power. Check to see if the fridge is plugged in and that the outlet is functioning properly.
2. Check the temperature control board. The temperature control board is responsible for regulating the temperature in the fridge. If it is faulty, it can cause the temperature to remain at a fixed, incorrect value.
3. Check the condenser coils. If the condenser coils are dirty or obstructed, it can cause the cooling system to malfunction and result in incorrect temperatures.
4. Check the door gasket. If the door gasket is damaged or not sealing properly, it can cause the temperature inside the fridge to become too warm.
If none of these solutions fix the issue, it is possible that there is a problem with the fridge's cooling system. In this case, it is recommended to contact a professional appliance repair service for further assistance.
Regarding the ice maker working intermittently, this could be caused by a variety of factors such as low water pressure, a faulty water inlet valve, or a problem with the ice maker itself. It is recommended to troubleshoot these issues separately.
Oven won't keep temp.
I would try another control board. I have gotten 2 new ones before that were bad right out of the box! It happens all the time.
Ge profile oven model jgs968 won t stay hot
If it has a thermocouple, replace that. They are cheap and easily available. They wear out after a few years.
OVEN FLAME TOO HIGH ON A A GE CONVERTED TO LP
You should have a pressure regulator between your stove and your propane bottle. It's probably delivering too much propane at too high of a pressure to the stove.. If you don't have a regulator, THAT would be your problem. A regulator set to too high a pressure makes flame too high and flame may even try to blow itself out. I've remedied this by taking a small cover off the center of the regulator and adjusting a screw.. (Not all regulators can be adjusted.) If adjusting isn't possible, I'd suggest a new pressure regulator (for LPG). Note: A regulator for LPG is NOT set up the same as a regulator for natural gas.
The power went out and now our GE refrigerator GFSS6KKX display on one side says 88 and the other is blinking back and forth from 86 and 88.
First try unplugging the unit for 7 minutes this usually causes the control to reset if it does not reset you may have to replace the control board 88 is a control issue. If you have any further questions message me back. I await your reply Thanks Rick
The temp setting goes up by its self. i can set it walk away and it goes up to 86
Sounds like it locked at that temp You might try reseting it by removing it along with the batteris and wait a moment replace the battieries and plug it back inot the base .
2helpful
3answers
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
The fridge gets very cold even when I turned down the temp to #1
You have air dampers in this fridge.
Adjust them to a warmer setting.
Look along the left wall down low beside the vegetable bins.
If this does not correct the problem you have electronic temp sensors that have gone bad.
A technician will be needed to determine that.
Keep your fingers crossed that the damper is too open.
Any adjustment will take 24 hours to be noticeable.
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
