The horizontal output transistor that drives the flyback transformer overheats now. There might be other reasons too for this fault. If the flyback transformer has any internal winding short, this transistor will overheat. Just replace the horizontal output transistor. Check its heat. If the newly replaced transistor too overheats, replace the flyback transformer.
this is hardware problem - replace flyback transformer & big transisitor fixed near flyback (replacing these two parts is compulsory ) - also check all small size transistors ( 6 to 10 transistors will be there on main board - see picture ) - below shown picture is only to get an idea as how these parts looks like & roughly where they are situated on main board ... that means this picture is not that of your monitor's main board - in your monitor there will slight difference & also that bigsize transistor's number will be different ....... for more details about flyback transformer check this link http://www.fixya.com/support/t10123898-panasonic_ct_36hl43g_tv_just_turned
Hello
Along with the flyback transofrmer, its horizontal output transistor also must be replaced. I don't know whether you have replaced it or not. If not, replace it too. It can be located very near to the flyback transformer, a three terminal component, black in colour, usually screwed to a metal heatsink. Then switch on the TV and measure the video output voltage at the video output card pluged directly to the picture tube neck. The collector of the video aoutput transistors must come around 145VDC. If it also is there, advance the screen control on the flyback transformer to get a raster. If that voltage is not there, it means that the flyback transformer is not working, and horizontal oscillator stage should be checked for oscillation, check the lined drive transformer for its primary winding open, Check the entire horizontal oscillator section. The collector point of the line drive transistor, the transistor that drives the line drive transformer, a small transformer soldered diretly to the printed circuit board; should be checked with frequency meter. The frequency at that point should come around 15525HZ approx: OK.
Hello Thanshar, Hi, you TV has sound, but no picture. this could be several things, and let us add the red led flash. In my analysis, no picture means no high voltage is reaching the picture tube. this could be due to a bad Horizontal output transistor, and/or a bad flyback transformer. This bad transistor is causing an overload to the power supply section, causing the 4 led flash to blink. Now i want to know if you want to do this service or get professional help. if you decide to do this by yourself, this needs to be performed: the Horizontal output transistor must be checked for short, the horizontal flyback transformer needs to be tested, the deflection yoke also needs to be checked, especially to horizontal coil.
I have a Samsung 32" that did the same thing a few weeks ago and I am still trying to fix it. The problem is the Main Flyback Transformer is blow with an open circuit in the Primary Winding that means you'll get no Picture. I also found the Power Transistor that feeds this Flyback Transformer was also shorted between terminals Collector Base Emitter(CBE). I bought a replacement Flyback but didn't work so now I need to get the Original part & it's not easy to find. Always use Original Components NOT replacements. Simply put if you're not technical I suggest take the TV to your nearest repair agent but be prepaired to pay for it. Cost of Flyback around US$50 & $10 for Transistor & if you find an honest repairman it should cost around $150 to repair otherwise it's not worth it. Good luck
Hissing noise and picture on and off means faulty flyback transformer, it has a small crack and voltage is leaking out, replace the flyback, if tv still not working replace horizontal output transistor (broken flyback could blow the transistor).
There is no "Flyback transformer" in the LCD monitor "Benq 17" model No. Q7T3". Such a component, a "Flyback transformer" is found in televisions and in Picture Tube type monitors. The red wire of a "Flyback transformer" is where 27,000 VOLTS comes out of to connect to the picture and such a voltage IS DEADLY so never enter a TV or computer monitor unless you know exactly what you're doing. To bring your hand too close to the "Flyback transformer" is to GET ZAPPED, you don't even have to TOUCH that transformer or the Red Wire that comes out of it!!!!
As far as a fuse blowing, NEVER PUT IN A FUSE WITH A HIGHER AMPERAGE RATING: it's there to protect certain components from being permanently damaged. If the fuse is blowing you must find out "why". There's got to be a short circuit in one or more components. Transistors, Diodes and Capacitors are easy to check for shorts. Transistors, Diodes are usually what short out. There's not much more I can say here.
A schematic diagram that shows the voltage on the many components of a running LCD circuit is what you need to find out where volatges should be. If a voltage is missing you must find out where the problem stems from. There are other ways to test circuitry, with an oscillascope and a schematic diagram that shows test points and the wave pattern that's suppose to be present.
The F27442 uses the CTC203 series chassis and that symptom is very common. If the horizontal output is shorted you MUST resolder the coil in series with the base of that transistor and the pins of the small horizontal drive transformer. When they have been properly resoldered you can put in a new original horizontal output transistor. If the output transistor shorts out again then your flyback (high voltage) transformer is shorted and needs to be replaced.
