Question about Kodak ESP5250 All-In-One InkJet Printer
Had the same problem error 3523 that would not clear. Tried Kodak support with no results so took matters into my own hands.
Noticed the top tray seemed jammed into the printer. Tried pulling it out but it seemed locked. Flipped the printer over, removed 8 screws, 4 metal plates.
Removed bottom tray, set aside. Remove 3 screws for plastic bracket that holds top tray. Move bracket over, be careful not to damage wires. Remove top tray and reinstall so that it is in extended position. There is two notched in the side of the top tray. Extend so that catch is in back notch.
Reassemble everything in reverse order. Take care that the top tray does not slide into the printer when you turn the printer over. It did for me the first time that the tray jammed again.
Replug everything and startup the printer with top tray extended past bottom tray. The printer will tell you that top tray is jammed, push top tray flush with bottom tray.
Printer now works. Don't know why tray jams in the first place but this solution can keep you from scrapping printer or paying for service.
Very disappointed with Kodak printer. Obviously printers were not their core business and they paid a sub-contractor to build these products for them. My next printer will be an HP.
Posted on Jul 21, 2012
SOURCE: Printer Jam. We have a Kodak Esp 5200 Series.
Try removing the gray cover on the back of the printer to remove the paper.
Posted on Feb 11, 2010
SOURCE: will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
If the error condition continues:
NOTE: If these folders are missing, the following error codes will be generated:
Posted on Dec 23, 2009
SOURCE: esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Posted on Jul 27, 2009
SOURCE: kodak esp 3 all in one
I Have one of these printers and it hasent been nothing but trouble
I wont buy another Kodak anything,
My solution, take it back and get a HP,
Posted on Sep 20, 2008
SOURCE: I`ve just purchaced a kodak
You can try to check if you have done the steps here. If everything fails, you might consider getting a USB cable to connect the printer directly to the computer first and use the Kodak Printer Setup Utility to connect. Make sure to install the printer's driver and software using the disc beforehand.
Posted on Apr 14, 2011
Aug 01, 2014 | Kodak ESP 7250 All-in-One InkJet Printer
Mar 29, 2012 | Office Equipment & Supplies
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mar 18, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Mar 14, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Aug 17, 2009 | Kodak ESP 5 Printer
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Apr 14, 2009 | Kodak ESP 5 Printer
2,776 people viewed this question
