Hello.
If you have an existing phone with which the BT2080 is paired, delete your headset pairing connection in that mobile phone. If you are uncertain, please provide the brand and model of that phone.
Then, follow the pairing instructions again for the BT2080: Press and hold the On/Off button for 5 seconds. The Bluetooth indicator on the BT2080 will flash blue when ready.
Hope this helps.
What happens when you press and hold the On/Off button on the BT2080 for 5 seconds ?
http://www.jabra.com/~/media/Product%20D... I think you press and hold the answer/end button, not the On/Off button. That worked for me.
SOURCE: how to reconfigure the H500 headset with a new phone?
Turn off your earpiece.Then turn it back on but hold the button until the blue light comes on and stays on.(that puts it in discovery mode) Now go to bluetooth devices in you r phone and search for the device.
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
SOURCE: can i pair WEP 210 with another phone
I had the same problem and solution 2fixed it, however to make the process a little bit more clearer i would add couple pf things: first turn turn ur headset off, then turn it back on and keep it held down untill u c a solid blue light and this blue light must be still and not flashing. now search the device on ur phone and u should be able to pair together and pin number will be 0000 for zero's
good luck
SOURCE: the headset was paired with old phone, but will
Have you tried putting the phone back in to pairing mode? To do this press and hold the call control button while the power to the headset is off. Then search for the headset with the new phone. When the phone prompts you for the passkey, enter 0000
Testimonial: "Thank you this worked out great. Just continue to hole the call button down until it flashes red and blue. Then it will pair with the new phone or device"
Deleted from old phone(blackberry 8300) bp2080 still thinks it is paired.
Ron
Does not work, deleted all blue took drvices from old phon, but bp2080 sill comes up as connected.
both lights flash for a sec, then left green light comes on solid.
both lights flash for a sec, then left light stays green.
