SOURCE: Husqvarna string trimmers 125c
Check for a spark. If none, then the coil is bad. Replace it. That should solve your problem.
SOURCE: Trimmer head wont spin on Husqvarna 125c. It seems
The drive shaft is not seated into position properly or the shaft has
broken. Have you had the shaft off recently? If so, take the shaft off
again and try to seat the shaft as you gently pull on the rope. If you
need further assistance, just let me know.
If you need further assistance, just let me know.
Jim
SOURCE: trimmer head line loading instruction
1. Remove the cap on the trimmer head, it unscrews.
2.
The spool comes off, and on the inside of the spool there is a small
hole, this is where you will start your trimmer line. It it will hold it
in place while you wrap it. There is also arrows on the spool showing
the direction that you need to wrap your spool.
3. Insert the
line in the hole and start to wrap the line in the directions of the
arrows, try to keep the line in rows, or else the line may bind and you
will have to do it all over again.
4. Feed the line through the
retainer and reinstall the spool by lining up the retainer and the slot
on the outside portion on the trimmer head, the screw back on the
trimmer head and you will be ready to trim.
