Hi type in Google search Dell 698 printer driver download. .. cheers
SOURCE: Dell All in One 922 Won't scan
download R151371 from e.g. http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R151371&SystemID=PRN_ALL_A922&servicetag=&os=WLH&osl=en&deviceid=6785&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=40&fileid=201464
Unzip it then find the folder containing it. Doubleclick on the "setup"
file... don't give it up yet...Inside the folder Apps you'll find
another "setup" file, doubleclick on it as well...That will install for
you the "All-In-One Center"...
Fingers crossed...
It worked for me...(but I was wandering why couldn't they make it more user-friendly?)
SOURCE: Dell 810 will not scan
I was able to get it to scan using the camera and scanner wizard through control panel, printer and faxes. On the left chose scanners and cameras in "other places" then when you see the dell printer click it and it will start the wizard. Make a shortcut to it to use again easily. I have given up trying to fix it!
SOURCE: Cant scan via network?
DJSting... paperport can be used for network scanning, as it works with the dell 2335. Now are you saying that this printer (the 1815) is limited?
SOURCE: I tryed to scan a paper. When I went to the
You have to uninstall the printer, go to lexmark site and download the most current driver (it's free), then reinstall your printer. make sure you restart your computer before you download new driver.
If you have a wireless router with a wireless network then -
Configure the IP address your wireless
printer, (this is done through the printer's menu settings) make sure it
matches the IP address range on your wireless network, it maybe 192.168.1.***
then configure the wireless printer with a fixed IP address with the same IP
address range but at a higher address eg. 192.168.1.10 so it does not clash
with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click
Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably
incorrect.
