Hi jerichoville,
First off, you have to be in an internet hotspot and your PsP WLAN switch should be turned on ( slide the switch at the left side of the psp upwards). A hotspot means that the area has internet signals that your wireless device can pick-up. If you are at home, make sure that your wireless router is functional.
Now, the steps :
-Go to the Main Menu of your PSP.
-Go to Settings.
-Scroll down to Network Settings (press the X button)
-Select Infrastructure Mode.
-Select New Connection and assign a name to the connection, then go to the next menu by pushing the Right Directional Key
-Select the Scan, you should now an access point
-Select an access point ( if you see multiple access points, select the strongest network with the Security setting of "None")
-Confirm your security setting from the different choices. "DEFAULT" is just about always the correct choice. Push the ">" button again and again until you reach "DEFAULT"
-Skip past the Address Settings by clicking the right directional button ">". You should now see a confirmation screen, just click ">".
- Press X to save your sttings
- Go to TEST CONNECTION and then press X (You should now be connected to the internet at this point.)
- Press HOME but this time use the ">" button to move all the way to the right, then "V" to go down to INTERNET BROWSER
There you go. Enjoy surfing. Wishing for you to get the best results. All the best to you.
