Question about Suzuki Boating
I just bought a suzuki outboard dt65 it sat for 6 years what do i need to do for water ready
Posted by nick_guinn on
paul
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Suzuki Master
  • 1,190 Answers
Remove carbs and clean jets etc ! clean or replace fuel tank and check primer bulb and line not perished ! check compressions and sparks ! remove gearbox and replace the impellor even if it looks ok and replace the gear oil ! run in tub of water for an hour to check cooling and the thermo opening also check no fuel leaks etc !
Posted on Jun 08, 2014
The two check eng and temp lights do not come on when I first turn switch to start on. Suzuki 60 2014
check the oil pressure first with a test gauge, as far as the other light goes have you over revved the engine?
May 22, 2016 | Suzuki Motor, Power Trim, DF60-70 98-00,...
HAVE TO REPLACE A CDI UNIT NEED A BREAKDOWN DT65 SUZUKI 6501
Suzuki DT65 1978 Wiring Diagram Page: 1 - iboats Boating Forums ...
forums.iboats.com/...suzuki.../296297-suzuki-dt65-1978-wiring-diagram Jan 5, 2009 - 6 posts - ‎4 authors ... diagram for a Suzuki DT65 6501 D-10978 (assume this is 1978). ... I looked around for a shop service manual on the internet, located a ...
Jun 23, 2015 | Suzuki Motorcycles
Suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Jun 19, 2010 | Boating
2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 | Boating
Need to know year of this outboard
Go to the Search, type in suzuki dt60, there will be many items to help. Its between a 1977 and 1984. Some of your numbers are serial #s and you can probably use the #6001 or the second number to be more exact.
Apr 30, 2009 | Boating
Boating Logo
130 people viewed this question
Top Suzuki Boating Experts
Marvin
Marvin
jws1013
Andrew Taylor
Andrew Taylor
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
