Norelco Quadra 7825 XL Electric Shaver Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The blades won't turn when the power is turned on. they seem to get stuck
chakkritc371
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Filmmaker:
Uploaded 5 video answers.
  • Contributor 31 Answers
  • Posted on Dec 04, 2012
chakkritc371
Contributor
Level 1:
Mentor:
Filmmaker:
Answers
31
Questions
0
Helped
11999
Points
72
Noreclo Quada 7825xl replacement heads is philips norelco HQ6 shaving heads.
shaveroutlet.com
Level 3:
  • Norelco Master 1,652 Answers
  • Posted on Jul 24, 2011
shaveroutlet.com
Norelco Master
Level 3:
Answers
1652
Questions
0
Helped
765000
Points
4209
If you flip up the heads and the shaver will rund without the blades engaged but will not run when the heads are snapped in place, this tells me that there are one or more damaged blades causing it to 'lock up'. You will need to replace the damaged blades.
You will find replacements for 7825XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq6-quadra-action-replacement-heads-p-250.html
1helpful
I have a staples SPL826X shredder and it won`t shredd, but it will go in reverse. can someone help me?
If you can disconnect the power to unit and check shredding blade alignments to see if there is a clog or if the blades are out of alignment and stuck. If there doesn't seem to be a problem with the blades make a visual inspection of the off/on/reverse switch.
1helpful
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
How to remove stuck blade bolt on MTD Mower model 449
Jeff:
First make sure that you are loosening the blade bolt (Are you turning it in the right direction?) Turn the mower on it's side and lodge a piece of wood between the blade and the body of the machine and really crank on that wrench. The blade bolt is probably rusted in the crankshaft.
Blades won't stay engaged in any length of grass
Sounds like a broken shear pin in the drive pulley. Check the belts and see if they are slipping. Broken shear pin will not let the blades spin under pressure. .
Aug 09, 2017 • Toro Garden
1helpful
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
My micro twister pro helicopter won,t lift off. all seems to be working fine
If it was the motor gear, the blades wouldnt be turning at all...some ppl are clueless :-/
Jan 03, 2012 • Toys
3helpful
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
