Heating & Cooling Logo
Posted on Jul 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just purchased a kenwood a/c a couple of weeks ago it's a G130EK, 13,000 btu and it doesn't cool anything not even a 12 x 12 room. There is an opening that leads to a bigger room , but the smaller room should as least be cool. I keep it at 64 degrees and still nothing . The exhaust hose gets warm and when I go out side to check the exhaust I can feel hot air coming through. What's my problem . Hope you can help Thanks !!!!
Thomas Woodburn
Level 3:
  • Master 2,638 Answers
  • Posted on Jul 02, 2017
Thomas Woodburn
Master
Level 3:
Answers
2638
Questions
Helped
1250606
Points
7008
Air conditioners generally cool the air 15 to 20 degrees. 80 degrees in return should be 65 in supply. 70 degrees in return should be 55 in supply. If the a.c. is in that range it is working fine and doing all it is going to do.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Feb 15, 2007
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Anonymous
  • 105 Answers
  • Posted on Jul 18, 2007
SOURCE: Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Anonymous
  • 9 Answers
  • Posted on Jun 25, 2008
SOURCE: air exhaust hose gets extremely warm
The Pinguino's exhaust pipe has to be attached to the window bracket to direct the air hot air out of the room, otherwise the room can't cool properly.
The owner's manual has several troubleshooting remedies for you to try:
1)  If the window is open, close the window. 2)  If there is a heat source in the room (burner, lamp, etc.), eliminate the heat source. 3)  If the exhaust hose is detached, connect the exhaust hose.  (My recommendation is to connect the exhaust hose to the window bracket and direct the air outside.) 4)  If the air filters are clogged, clean or replace the filters.
Remedies that aren't mentioned in the manual, but you might find helpful:
1)  Make sure that there are no kinks in the hose, and that the hose either remains straight or has a gentle curve when directing it into the window bracket.
2)  A sunny window reduces the maximum power and efficiency of the unit.  Placing it in a sunny window reduces your BTUs by at least 600, which means the maximum square footage of cooled space is reduced.  Cooling a kitchen requires at least 4,000 BTUs alone, which is nearly half of the unit's BTUs.  Try to place the unit by a window that receives minimum to no direct sunlight.
Finally, stating the obvious, if the room isn't cooling, the room is too large for the unit.  The PACL90 cools up to 400sqft.  Bear in mind that the air from these portable air conditioners cannot move around corners very well, so try to set it by a window in the central part of the room.
Coss
  • 1056 Answers
  • Posted on Sep 08, 2008
SOURCE: Not cooling anywhere near what it claims.
Yes, you have hit all of the right points.
But in simple terms, air is like water, you can only move as much out, as you take in. So if the room is sealed, it does not have an air source to draw from. Even though the units have the exhaust port set correctly, they do not have a source to draw from. If the room is completely sealed, if they exhaust only, it will begin to create a vacuum in the room. Since these units are not powerful enough to create a negative atmosphere, they simply do not provide any cooling.
I use a portable Sharp unit in my server room. I do have a fresh air feed to the room, through a separate system. I have done a number of server rooms, and they are never completely sealed, they have air feed and exhaust systems. They just are not usually visible.
The reason the window unit worked so well is because it could draw outside air. With the way you have described these, no, they will not be as efficient, because they can't draw outside air.
So how do you fix it?
You can do like I did in my server room, and have a fresh air, filtered supply pumped into the room (or just in front of the cooling units).
Or, (and this is going to take a little engineering) put the cooling system in another room that can draw exchange air, and duct the cooled air into the room. Here again, you will need to have an exhaust system that will remove the hot air from the room.
If you baffle the supply line correctly, you will eliminate sound transmission.
The units you have, are good units, and very similar the Sharps I run.(they are probably built by the same people).
I have not found any recalls or complaints about the units.
Anonymous
  • 148 Answers
  • Posted on May 19, 2009
SOURCE: Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
The power on my N120E - DeLonghi 12,000 BTU Portable Air turns itself off
The DeLonghi Pinguino Air Conditioner is such a smart choice for people in need of a little extra cooling in their homes! My better half purchased our a couple of years ago when he realized his office was getting much warmer in the Summer than the rest of the house. Being hot natured, he thought a portable air conditioner would be a smart choice. We've loved it! It's on wheels, so you can move it from room to room quite easily (even my 10-year-old has been known to move it.) It's outside vents attach to an adjucstable plate that fits right in any size window in seconds. Just select what temp you want it and... done! Super easy.Right now we're currently using it instead of our central unit while the temps aren't too very high.
In a 10x23 room with lots of widows how many BTU air conditioner do I need?
The dimensions you gave only equal 230 sq ft. It may seem larger, because it's long and narrow. Even with lots of windows*, you shouldn't need more than 15,000- Btu's to cool the area comfortably. *That's assuming you close the blinds, shades or curtains, while the room is in direct sunlight. Even with a higher Btu output, those "lots of windows" will always be an air conditioners worst enemy. So, in your case, more is not better. In fact, it's a waste of energy.
If you have a ceiling fan in that room, run it on the highest speed that comfortable to you, in a clockwise (looking up at the fan blades) direction. This will help move the cool air around and generate a wind chill. That will make it feel cooler than it really is. Plus, it takes the strain of the AC unit.
I hope this helps you and thanks for choosing FixYa.
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
1helpful
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
3helpful
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Is this model number a 13,000 or 15,000? and whats the difference
Hi, I don't see a model number? I can tell you that for each ton of cooling, you will have 12,000 btu's. So, at 13,000 and 15,000 btu's of cooling, they both are just a little over 1 ton of cooling. Tons are a measurement of btus in a/c and heating applications. Give me the exact model number itself, and I can tell you the tonnage.
Thanks,
Shastalaker7
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Top Kenwood Heating & Cooling Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
