Check your manual to make sure that you can re-calibrate the thermostat as long as your clock is working., the timer works, and the START button is working. If the timer can't be started, it may b3e a touchpad problem. Do you have F1 error message? If nothing is working then there might be a tripped circuit breaker.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
heatman101
If
problem.
Oven
heatman101
If
problem.
Oven
heatman101
heatman101
