Maytag PAV2300 Top Load Washer Logo
Posted on Jul 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to take the motor out - Maytag PAV2300 Top Load Washer
Anonymous
Level 2:
New Friend:
  • Expert 68 Answers
  • Posted on Jul 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
68
Questions
Helped
11506
Points
110
Remove the springs on the motor carriage (this will make it easier) then undo the three 8mm screws holding the carriage on the machine base (1 on the outside and 2 on the shaft side of the carriage). Then you can remove the carriage without having to remove the motor pulley. The remove the motor from the carriage simply remove the four nuts from underneath the carriage.
SHARP AR5620SL CODE L4
  • Code: L4 01
  • Description:Main motor lock detection. The main motor does not rotate. After rotation of the main motor, the motor lock signal is detected for 1 sec or more. During rotation of the main motor, the motor lock signal is detected for 1 sec. When the main motor is stopped, the motor lock signal is not detected for 5sec or more. (Though the motor is stationary, it is judged as stable rotation.)
  • Causes:Main motor unit abnormality Improper connection or disconnection the main motor and the harness. MCU PWB abnormality
  • Remedy:Use SIM 25-01 to check the main motor operations. Check connection of the main motor harness/connector. Replace the main motor. Replace the MCU PWB.
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Model 841.205 lw2019. Where can I buy 13 vdc motor?
13v Dc Motor - Alibaba.com
www.alibaba.com > Mechanical Parts & Fabrication Services > motor
13v Dc Motor, Buy Various High Quality 13v Dc Motor Products from Global 13v Dc Motor Suppliers and 13v Dc Motor Manufacturers at Alibaba.com.
12V DC Motor ' eBay
www.ebay.com/bhp/12v-dc-motor
eBayFind great deals on eBay for 12V DC Motor in Electric Motors with Less Than 0.5 HP. Shop with ... Buy It Now. 209 watching ... Igarashi 12 VDC Motor - 4500 RPM - 12 V - Toy Car and Hobby Motor - High Torque. $6.95. Buy It Now ... Worm Motor. Output Shaft Size 1.5 x 13mm/0.06 x 0.51 (D*L) Shaft Total Length 47mm/1.7.
Ametek Motor ' eBay
www.ebay.com/bhp/ametek-motor
eBayAMETEK MOTOR GENERATOR E56617 72 V DC WINDMILL TURBINE PERMANENT MAGNET WIND. $145.00; Buy It Now ... Ametek/Lamb 116765-13 Vacuum & CentralMotor, NEW 110 volt 3 stage. $114.79. Buy It Now. Free Shipping.
How to change ac blower on a 2001 chevy silverado with the 5.3 liter v8
With Delphi Blower Motor
  1. If equipped, remove the sound insulator panel.
  2. Remove the blower motor insulating cover screws.
  3. Disconnect the electrical connector from the blower motor.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
  6. Remove the blower motor.
With Visteon Blower Motor
  1. Remove the sound insulator panel.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the screws from the blower motor.
  4. Remove the blower motor from the HVAC module.
  5. Remove the retainer from the blower motor wheel. Discard the retainer.
  6. Remove the blower motor wheel from the blower motor.
Electric motor keeps cutting out
There may be a thermal protector placed internally within the motor or motor-compressor to protect the motor and motor winding's components from dangerous overheating that can cause motor failure.
This overheating generally occurs when the motor is overloaded, a bearing seizes up, something locked the motor shaft from turning, or the motor simply fails to start properly. A failure to start may be caused by faulty start winding's in a motor.
The thermal protector consists of one or more heat-sensing elements integral with the motor or motor-compressor and an external control device. The thermal protection is in place to turn the motor off when excessive heat is generated within the motor circuitry and keep it from burning up the motor.
These thermal protectors are reset when the motor cools to a safe operating temperature. There is usually a visible red button located on the wiring side of the motor, opposite of the motor shaft, but not always. In some cases, these buttons are reset manually.
Mar 10, 2014 • Garden
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
1helpful
My W840 message : 9.12.00 Service Motor Error
The PC (photo conductor) cartridge motor does not rotate at the specified speed.
Check the PC cartridge for installation.
Is the PC cartridge installed securely?
Check the dual drive motor assembly for operation.
Open the rear motor cover and check it.
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Drum unit motor.
Does the motor rotate normally.
Check the dual drive motor assembly for installation.
Is the dual drive motor assembly installed securely?
Check the rotation of the rotor in the dual drive motor
assembly.
Can the rotor be rotated by hand without excessive load?
Check the dual drive motor assembly connection.
Is the dual drive motor assembly properly connected?
4helpful
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
6helpful
How to replace the blower motor fan assembly in a 2000 GMC Yukon XL K1500 4X4
Blower Motor Removal & Installation Delphi
Blower Motor Replacement (Delphi)
To Remove:
  1. Remove the instrument panel sound insulator panel (if equipped).
  3. Remove the blower motor insulating cover screws.
  5. Pull the retaining tab down and rotate blower motor counterclockwise to remove.
To Install:
  1. Position the blower motor and turn assembly clockwise until tab locks in place.
  2. Install the blower motor insulating cover.
  3. Connect the electrical connector to the blower motor.
  4. Install the instrument panel sound insulator panel (if equipped).
Visteon
Blower Motor Replacement (Visteon)
To Remove:
  3. Remove the blower motor screws.
To Install:
  1. Position the blower motor and install mounting screws.
  2. Connect the electrical connector to the blower motor.
  3. Install the instrument panel sound insulator panel (if equipped).
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
