Question about Durabrand HT-3915 System
Need codes for ht3916 to chage remotes - Durabrand HT-3915 System
Posted by grizzly6605 on
Bill
  • 30 Answers
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Posted on Jul 23, 2011
How to change channels with a sci braodband remote. the tv turns on and the volume works but i cant chage channels
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts. ..
Jun 02, 2016 | Motorola Televison & Video
My Hisense LCD 32V77 tv is no longer chaging channels by remote and even with buttons so what might be the problem?
that tells me you need to take it to a repair shop to have the buttons either cleaned or replaced .
Nov 30, 2015 | Hisense Televison & Video
I went and bought a RCA rcr6473r remote n put new batteries in it but d light never come on wut is the problem
If the polarity of replaced battery have chaged, the remote won't work. Check it first.
Jul 26, 2013 | Televison & Video
How do u change the fahrenheit scaling to celcius scale in the voltas ac... via remote control
Voltas remote..instructions are given behind the remote.
Off remote.
Press mode and - .
chages d unit of temperature.
Sep 16, 2011 | Heating & Cooling
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
What is the remote access code for a sanyo DS24205?
Normally all sanyo kits have two remote acces codes. One is Press Sleep Button on the remote handet and Menu button on the front panel of the TV simoultaneously.
Second is a tricky one.
Press Volume+/Vol_ to set the volume level to zero and press 'REP' on the remote control hanset aln loosen.
Keep pressing Vol+/Vol_ on the unit and press 'REP' on the remote control again.
Factory status will be displayed.
This is the service mode. You can adjust the parameters with the help of programe and volume control buttons.
To exit from the service mode, do the above said three again, unless the chaged parameters will not be stored in memory.
Another method is, if the hanset has a hidden key, usually at the lower side, which seems as a small hole. press it with a small stick to fit, may enter to remote code options.
Oct 13, 2010 | Sanyo DS24205 24" TV
My touch pad remote is not programed
Hi, drop down panel door. enter installer code. you need to know what zone it was on before, because I recommend you try to delete it first. so next delete then sensor remote button til you get to right zone, then "done" then use add button sensor remote button then if its the small remotes 2 botton press the 2 bottons. for botton press top 2.sensor group 01
Jan 03, 2009 | GE Security Simon 3 Wireless Home Security...
Universal Remote
CHAGE YOUR MAINS LEAD
Mar 23, 2008 | Sony DAV-S500 System
Code(s) for Philips TV
do you know how to chage codes? if you dont know contact.this are the codes.
philips tv 011,056,043,017.
sony 001.
Feb 25, 2008 | Sony RM-EZ2 Remote Control
Durabrand HT-3915 System Logo
843 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Geoff
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
