Question about Beverage-Air BEVBM23 Commercial Beverage Dispenser
I have a BM-23 direct draw kegerator. There is a large amount of water accumulating on the stainless steel floor plate inside the unit. There is a drain line running from just below the circulation fan (at the top of the unit), but nothing seems to drain into the pan underneath the unit. What could be the problem?
Posted by dfoss1492 on
Jay Finke
  • 1,389 Answers
Its plugged, try a piece of say 16 gauge copper wire or a piece of weed wacker trimmer line(best) to snake it out
Posted on Jul 23, 2011
Cannot unlock draw
Usually a locked draw is caused by an electronic controller failing.To open the draw you can pull it with even firm pressure but do not try and close it as thelid is in the "down "position.Before closing you must go inside chassis by pulling out the affected draw ,unclip the lid motors from the lid supports and push the lid up to the raised position and then wind the arms of the lid motors to the new height,manually and then clip the lid motor arms back into the lid supports.Then replace the draw.Then you must replace the electronic controller...
Jan 06, 2011 | KitchenAid 23 in. KUDD01DPPA Stainless...
The cooler will not cycle off when temp is reached. Just keeps running and becomes a freezer instead of a refrigerator. Where is the thermostat adjustment locatd on a True Model T-23
Inside of the unit on the right side of the coil. You may need a little mirror to see it easier. There is a metal plate with a little v cut to indicate where the setpoint is and the knob should have numbers from 1 to 9. The typical setting is 5.
Nov 16, 2010 | True T23 Stainless Steel Refrigerator
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
Need instructions and part # for lp conversion kit on MGR5765QDS
Your conversion jets are usually located beneath the hinge area or the back panel on that stove and are mounted on a plate which holds all of the LP jets in a row. there is no need to buy a conversion kit, since it is already supplied. The jets mount on the burner control itself as it enters the gas flow tube, and the oven jet mounts just before the large burner under the plate in your oven area. Just remove that large oven floor plate and you will see it.
Mar 23, 2010 | Maytag MGR5765QDS Stainless Steel Gas...
Dishwasher is not cleaning well, leaving a lot of grease behind and dishes are not drying
Hello- This unit has a filter that will become blocked by large quantities of grease over time. The accumulator screen clogs and water won't flow. If grease has been building up for awhile this screen will have to be replaced. -- Rinse most of grease off dishes before putting in dishwasher--. Try running water at sink until hot, and run dishwasher with no dishes and a little extra soap. Let me know if this info helps- Have more if needed.- Thanks- Ed
Mar 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food on dishes
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Beverage-Air BEVBM23 Commercial Beverage Dispenser Logo
193 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Marvin
Marvin
Paul G
Paul G
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
