SOURCE: Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
SOURCE: iMATE jAQ aLIGN SCREEN
Remove the battery...from ur mobile.....
and happy............... its my suggestion
SOURCE: Modem drivers for imate Jaq
I have i-mate JAQ. I want modem drivers of JAQ for xp operating system.
Could you please tell me the path or the link.
Thanks in advance.....
SOURCE: how to do factory reset of i-mate JAQ
here is how to do a hard reset:
note: all three at the same time
1)push stylus into soft reset hole + press FN key + press right soft key.
2) phone will restart to factory settings
enjoy.-->
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
running slower than normal, or a program is not performing properly.
A soft reset is also necessary after the installation of some programs.
If a soft reset is performed when programs are running, unsaved work
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings — the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
programs will remain.
To perform a soft reset
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard reset
Hard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Your battery has been depleted past a chargable state. This is a due to a bad design in the phone that doesn't monitor the battery power state well enough. It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
