Question about Mountain Buggy Urban Single Stroller
I havde lost the buttom u press to move the handle up and down. where do i get another?
Posted by hayley31 on
Liz Wanden
  • 419 Answers
If you are within the UK, call 01234 344230 to order parts. This is the Uk distributor.
Hope this helps.
Posted on Jul 23, 2011
95z28 camaro automatic transmission shifter buttom will not release
Could be something broke inside the T handle or inside the console.
Have you taken the console apart to look at the lock pin ?
Mar 08, 2014 | 1995 Chevrolet Camaro
Technics sl qd33
tone arm could need cleaning never done it personally but if you take it to a stereo shop they should b able to help you
Sep 19, 2013 | Audio Players & Recorders
I just got the Ricoh VT6000 and I can not figure out how to properly load the master
as far as i remember press the green button on the right side of the machine while pushing toslide the scanner. move the green lever to up to insert the master between the two roller the rubber and the foam rollers then down the lever to lock. press the green buttom located on the right side to load the master. while loding move the green lever up down up down to balance the weight on the master to avoid skewing then down to lock. hope i help, good luck
Sep 01, 2011 | Ricoh Priport VT6000 Copier
The driver's side door could not be opened inside with interior handle. I have a 2002 volvo v70. Everthing seems ok before I pressed the central locking buttom at driver door armrest. Now the driver door...
you"ll have to remove the door trim and replace or reposition the cable/rod assembly that has move out of position not too hard to fix dont worry
Jun 05, 2010 | 2001 Volvo S60
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
Need a Code Number to work with my Dish
5-Press record
This way of finder code make the remote search 1 by one , usually dvd and other things else than television dont work , but give it a try might work but probably will just power on and off not more than that but will work fine with ur tv
Jan 11, 2009 | Curtis DVD-7600 DVD Player/VCR
I have a bell express vu remote that i am trying to get to work with one of your tv's. the remote is a 3.2IR the model number of the tv is 20pt634v37or 2opt634v37 can u please help me figure out wut the...
5-Press record
Finish :)
Jan 06, 2009 | Directed 434MHZ Remote Control
Remote codes
5-Press record
Jan 03, 2009 | Bell SH50102 Remote Control
Bell express vu remote codes for soyo tv
5-Press record
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
U700 troubleshooting
When you see all of the icons displayed on the phone, the settings icon is the one in the bottom right hand corner. Press this once and it automatically comes to phone settings which is No. 1. press this once and and scroll down just once which is phone language. You should then be able to change it to English.
Feb 18, 2008 | Cell Phones
Mountain Buggy Urban Single Stroller Logo
150 people viewed this question
Top Mountain Buggy Baby Gear Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Mountain Buggy Baby Gear Expert? Answer questions, earn points and help others
