Hello Peter,
Once the device has been neglected for oil long enough you will get this error code. Usually people don't wait until the code occurs. You WILL INDEED need to go into service mode. To do this,you will need to follow a fluid 3 step process. First locate the "CLEAR MODES" key located obove the 9 key pad. It is yellow. Now locate the red STOP button located below the 9 key pad.Ok, to enter service mode you will need to press "Clear /Modes"and release,then press the numbers "1,0,7" in a 3 step sequence and release, then press the red STOP button and HOLD it down till the device beeps. The screen will change and say service mode. Press "COPIER". The screen will change again. Using the keypad press 5,8,1,0 and then press the pound sign {#}. You will be prompted/asked to EXECUTE. Press EXECUTE. Now unplug the device while in service mode after the execution of the 5810. Wait a sec, plug her up, and you are done. Have a good day and let fixya know I helped. :-) SPINAL
Testimonial: "100% esfffective"
Insufficient oil (the oil tank in the rear of
the machine)
