SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
SOURCE: my tv is LG 42LG2000.
kindly check with the company who you got the module from..i am sure they will be able to help as they have a working knowledge of the module along with manual.good luck.
