Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
How to hook up speakers? Sound sounds muffled
Posted by willowstarda on
Fred Yearian
  • Behringer Master
  • 5,603 Answers
You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
Posted on Jul 23, 2011
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
I have a behringer pmp6000 no sound
No sound at all, or just to the "r" (rear / right?) speaker? Can you be a bit more specific? Will be glad to help.
Jan 13, 2013 | Behringer Music
Sound gets muffled at certain frequencies. Please Help!
I think that rather than the mixer, that your front speakers may have a limiter built into the high frequncey amp. You may be asking them to do more that they are capable of.
Mar 04, 2017 | Behringer Sx2442fx Eurodesk 24channel...
ONLY GETTING MUFFLED SOUND FROM ONE OF MY MACKIE SRM V2 SPEAKERS,HAVE CHANGED DIAPHRAM BUT PROBLEM STILL THERE
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
May 04, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
My behringer b203a is making a loud muffle mono feedback sound when i am trying to use it. what could be the problem? please help!
this is normaly a wiring or amp issue. if it was the speakers they wouldnt make any sound or they would crackle or buzz
Jan 31, 2011 | Behringer B3031A 2-Way Active Studio...
Fender Hot Rod Deluxe has very little sound, stuck and need help! Turn it on and all of tubes light up. Has a horrible muffled sound with volume at 5. Master volume can be put to any level, and it doesn't...
Just because tubes light up does NOT mean they are good or working... While heaters not lit are an indication of failure, teh reverse is not necessarily true.
Time to troubleshoot this... Plug a set of headphones into teh preamp out. See if audio there is clean... it will be low level using headphones and ONLY from one side as the output is mono and your headphones are stereo usually... If audio is clean here and not muffled, then problem is in power amp section else in the early stages of the unit.
Report back the results of this test...
Nov 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Jan 24, 2010 | Crate Music
Roland KCW-1 subwoofer speaker problem
I sorry to say but you may have cooked your speaker , I have lost quit a few in my day this sounds very famillar.Try takeing it down to a audio shop and have them realy ck. it out. thats the only real way to be sure. this is a good speeker and they don;t come cheep. they probubly wont even charge you I wouldent. good luck DFD
Apr 09, 2009 | Music
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
386 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
