2005 Honda CR-V Logo
Posted on Aug 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Navigation System Disc in Honda CRV not working
When I start car SAT NAV screen says this error " DVD disc is reading an error"
  • 4 more comments
  • Anonymous Nov 16, 2008
    Same problem - 2004 CRV though - not uncommon.. I did find this but doesn't seem to work in our car
    http://www.howtomendit.com/answers.php?i...
  • Anonymous May 26, 2009
    me too! Same problem
  • Anonymous Jun 25, 2013
    2006 Dodge Ram 1500 nav disc will not eject any soulutins?
  • Anonymous Mar 16, 2014
    my navigation disc isn't reading when i put it in, the screen just keeps saying to enter the disc even when it is in
  • Anonymous Mar 24, 2014
    When I enter a place name in the Nav System, it directs me to places very far away and doesn't even list the closest place. For example, I entered Costco and it only listed Costco stores that were over 1000 miles away. I set it to sort places by distance but that did not help.
  • Anonymous Mar 27, 2014
    centre console display does not work, there is power to the screen but it just goes black when the ignition is turned on
Kaaren
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2015
Kaaren
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4626
Points
I have honda crv 2006 but Navy doesn't work
what to do?
It doesn't start up at all.
Please can someone help? [email protected]
Thanks in advance
Anonymous
Level 1:
New Friend:
  • Posted on Apr 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4626
Points
what to do?
("dvd dis reading an error")
my email is [email protected]
Anonymous
Level 3:
President:
  • Master 1,263 Answers
  • Posted on Aug 29, 2008
Anonymous
Master
Level 3:
President:
Answers
1263
Questions
Helped
682988
Points
4577
Your best possible solution is to take it to the dealer they most like ly will have to download a programing patch to repair the problem.
  • Anonymous Jun 10, 2012
    Local Dealer referred me to a local auto audio shop. Took it to Dealer in NC that will update GPS data, but they could do nothing. Cost to fix $2,645.00!!!
Sat nav disc reading error 56 plate civic
get it serviced
the magic smoke was lost.
Screen says; dvd disc reading error please consult your dealer
I can repair your Honda crv. accord.civic type r When it says disc is reading an error. mobile service i come to you in about one hour your sat nav will be working fine again. I also do a postal service aswell. Also if you are having problems with the ENTER BUTTON i can fit a new one. Call Andy On O7765846880. If i don't answer leave a message and i will call you back
1helpful
I have a navigation system and the dvd shows a reading error
bad or scratch disc/ clean it with rubbing alcohol...try using different disc, if it does not work then have the nav sys check.
4helpful
2006 Jeep Commander AWD 4.7 L. Navigation system is NOT WORKING
Its usually not the nav unit. Best way to find out many dealers have a demo nav disc ask them to pop it in if it works then u know the disc is at fault not the nav unit. The bad news it the disc costs about $300. Hope this helps please rate if it does.
Honda CRV 03 Sat Nav instructions required
did you find the manual? i need the same manual (its for my CRV 2004) but I'm sure its the same model of DVD sat Nav. looked on the net everywhere.
1helpful
Navigation system not working 2005 Honda Pilot
Hi,welcome fix ya. the correct disc for your pilot has a black label and the version should be between 2.11c to 2.60 any other disc will not work in your unit. If there is anything else I can help you with let me know.
A8 2004 Navigation system not active
NAV unit uses a DVD disc. If its a copy, it may or may not work. I suggest you remove the NAV disc, unplug the NAV unit from power for 4-5 minutes, reconnect the NAV and try inserting the disc again to see if it reads. If it still does not read, another NAV disc needs to be inserted to verify its not a "bad" NAV DVD disc issue. If it still cannot read the second disc, the NAV unit is bad. The handbook feature needs the disc inserted in the slot 1 of the CD changer unit.
1helpful
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
2helpful
Sat nav
ok I fixed it....took out the sat nav and cleaned the lens with a cotton bud..WORKS!!!
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
