Question about Kodak EasyShare Z740 Digital Camera
The lens won't come out anymore on my kodak easyshare z740. When i turn it on the lens trys to come out, it can't so the camera turns off. Is it fixable?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
5 Suggested Answers
Anonymous
  • 2985 Answers
SOURCE: Dropped Kodak Z740 lens won't open/close
This is not a simple fix
Indeed it may not be fixable
With so many new models coming on line all the time parts are usually available
Kodak Support will advise
Posted on Dec 28, 2007
Anonymous
  • 2985 Answers
SOURCE: Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Posted on Jul 18, 2008
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: Have Kodak easyshare Z740 camera, turn on and goes
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
Anonymous
  • 68 Answers
SOURCE: Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Posted on Oct 16, 2009
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: kodak easyshare Z740 battery problem
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Posted on May 01, 2010
The lens thing gets stuck wont go in or out and camera shuts down
I may be able to help with your Kodak EasyShare Z740 with a stuck lens.
I hope that helps.
May 05, 2010 | Kodak EasyShare Z740 Digital Camera
My camera turns on but turn off right away why?
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
Apr 27, 2010 | Kodak EasyShare Z740 Digital Camera
Camera turns off when you use telephoto lens camera turns off.
I hope that helps.
Apr 21, 2010 | Kodak EasyShare Z740 Digital Camera
Camara wont stay turned on
I hope that helps.
Apr 15, 2010 | Kodak EasyShare Z740 Digital Camera
My z740 camera will not stay on
I hope that helps.
Mar 19, 2010 | Kodak EasyShare Z740 Digital Camera
My camera will not turn on at all and have put in new batteries
I hope that helps.
Dec 28, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak z740 will not turn on
I hope that helps.
Mar 29, 2009 | Kodak EasyShare Z740 Digital Camera
Camer comes on for 15sec then go off
I hope that helps.
Mar 03, 2009 | Kodak EasyShare Z740 Digital Camera
Dropped camera, SD card came out. Took 2 more pictures, camera turned off. Replaced batteries, camera turns on and then back off.
I hope that helps.
Jan 03, 2009 | Kodak EasyShare Z740 Digital Camera
Camera goes off
I hope that helps.
Oct 15, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
156 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
