Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
After inserting USB 4GB key in PS3, I get the message... USB is locked. I tried to find the lock/unlock switch on USB as suggested in dane-elec forum but can't find it. What to do ?
Posted by cpelletie927 on
Brian Sullivan
  • Dane-Elec Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
hope it helps
Posted on Jul 23, 2011
My new UBS 4GB from DANE-ELEC refuse to open. it says all time inser disk
Unfortunately your USB drive is faulty. You can try to open it up and see if the chip is fitted properly on and if not solder it back into place, but my suggestion is to get a new one.
Dec 10, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
How can I remove the write proctection off of my dane elec 4gb thumb drive
There should be a physical little lock /unlock switch on the key drive somewhere. Its in the locked position. find it and switch it a few times then try again.
Sep 02, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane Elec 4gb USB Not Readable
Try it in a different computer or even a different usb port on the computer that you are using. If a second computer gives you the same error, then the drive is either damaged or its filesystem is corrupted. In the first case there is not much you can do. In the second case you may be able to reformat it to make it work, but you would lose any data that was on it.
Mar 25, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Missing driver for dane elec 4gb usb flash pen (Operating system XP)
No zMate Pen driver is necessary to work out with Windows Millenium, Windows 2000, Windows XP and MAC OS 9.1 and more: they are plug and play.
but try this site:
http://www.dane-elec.fr/scripts/home/publigen/content/templates/TPL_ADV_INFO_C2_S4.asp?P=352&L=EN
Jan 11, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
My computer fails to read anything from my USB. It recognizes the device but when i try to retrieve the information, it keeps telling me to insert disk into drive f. HELP!!!!!
Does the OS recognize the device, install the "Mass Storage" drvier, etc.? If it does, try uninstalling then reinstalling the drivers.
http://www.dane-elec.fr/scripts/home/publigen/content/templates/TPL_ADV_FAQ_01.asp?P=282&L=EN&SYNC=YES#35
Here's a link to the drivers from that companies website, you might try them.
http://www.dane-elec.fr/home/liblocal/DOCS/Drivers/zMate%20Pen%202/zMate%20Pen%20usb2.zip
This also may be a problem with USB versions too. I have a 4GB Deisel USB drive and it will not work on any USB 1 devices.
Jan 04, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-elec 4GB usb insert desk problem
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Nov 22, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Write protected memory card..sd card
There should be a little switch on your memory card reader, if it is facing down, your card is locked. Push it up and then you should be ready to go. :)
Jul 07, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
My 4gb dane elec doesn't let me ready boost, and it has nothing on it!
bonjours je vient de machetter une cle usb dane-elec 4GB l'ordie pas de pilote logiciel DISK2.0 je suis sur wista merci d'avance
Mar 21, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
358 people viewed this question
Top Dane-Elec Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Hetman Software
Hetman Software
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
