I have a wurlitzer OMT 1990, 50 cds,the gripper works take cd and put on the laser but laser not works after a few time,gripper take the cd and put in the rack.When the juke is cold it works, sometime it as time to play two or four tunes and laser stop to turn,Can you help me.Thank you Vizio
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
The carousel is locked in position by the latch at the front (about 6 oclock). If the gripper isn't exactly in line with the cd then you need to adjust the latch a bit.
There is a white bracket on the far side of the gripper arm which comes loose so it doesn't click the microswitch beneath it. To prove this press o the bracket when the arm is over the cd magazine and it will stop.
There's a spring wound round the shaft of the rod that drives the gripper gears. Oil very lightly. The gearbox rotates when it puts the arm back but the arm is held against the driving part by this spring so if it is sticking the arm will not turn over properly even if the drive shaft is doing what it is supposed to.
I asked a Wurlitzer engineer about this problem and he simply said, "Bend it a bit."
Sounds horrible but there is no genuine adjustment. But before doing that, try moving the carousel lock latch (at the 5 oclock position). This is what locks the carousel and determines its position when the correct CD number is reached. If you could ****** or advance it a little it might work.
