The "F1" fault code indicates an error in the electronic oven control circuitry. The failure is most likely the electronic oven control board and a slight possibility of a faulty oven temperature sensor probe. The oven temperature sensor should have a resistance measurement of 1050 to 1100 ohms at room temperature. The oven temperature sensor can be remove from inside the oven cavity and tested using an ohm meter. If the sensor measures approximately 1050 to 1100 ohms, replace the oven control board.
