SOURCE: washing clothes all day have an F35 flashing
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
SOURCE: MY BEKO 1613S WONT WASH MY CLOTHES
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
SOURCE: The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
SOURCE: How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
Testimonial: "it works!! thanks"
SOURCE: I have a beko wma620 washing machine. power is
had same problem change the motor brushes and all wil be ok £20 and one hours work easy ....kev......
