SOURCE: Bosch KGV24V01GB Fridge Freezer -
Try increasing the temperature of the freezer (closer to -5) for a few days. It could be you have it too cold.
At certain times it should feel warm in some places on the sides, or you may hear a fan running. If you don't get this, there may be a fault in the defrost circuit, timer or fan.
Make sure vents are clear, and that door seals are in good condition. A faulty door seal admits warm damp air which then freezes.
Where is the ice forming?
SOURCE: frost free fridge freezer has
yes,
you have a defrost problem, three things..
one, defrost heater could be bad,
two, bi-metal could be bad,
and three, the timer could be bad.
any of these three items getting bad would result to one symptom.
ice buid up at the bottom of freezer section.
tnx 4 using fixya,
drcool
SOURCE: Evaporator fan stops working due to ice buildup around fan.
you need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
SOURCE: ice buildup on bottom of freezer
yes, the drain is clogged, remove all food from frige and freezer and defrost with a hair dryer,go the the freezer section this is where the issue is, you need to poor hot water into the drain trough located just below the evaporator, chase the drain with a coat hanger with the hair dryer on the coat hanger this with heat up the coat hanger enough to melt and free the clog.
nbcrca:)
SOURCE: Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
