2006 Acura RSX Logo
Posted on Aug 29, 2008
2005 Acura RSX
My seat belt is locked out from a wreck. Can you please let me know how I can reset the seat belt. This would not fall under warranty. Thanks
  • stepshane5 Aug 29, 2008
    Can anyone help me out!!
Anonymous
Level 1:
Problem Solver:
  • Contributor 21 Answers
  • Posted on Aug 29, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
21
Questions
0
Helped
11272
Points
31
The buckle and belt need to be replaced.  They are only good for one time during a collision.  The buckle has an explosive charge in it that causes the buckle to pull back toward the seat.  The belt does the the same.  It locks up during an accident, also so body shops can't try to reuse it.  The SRS light will stay on until they are replaced.
Vechile battery ground problems on 2005 acura rsx type s
Make sure your battery terminals are clean and tight.
4answers
How do I get the SRS light on my 1997 Acura rl to go off
You have a module that's going bad or is bad. Someone had either wrecked the car previously and didn't replace all damages modules. You can have a shop put on computer to tell you exactly which one needs replaced. There is one on the front of the vehicle one under drivers seat and one in with the seat belts those ate just sensors the actual modules are the site bags themselves
1helpful
How to change passenger front belt buckle
First, in the United States, seat belts have a lifetime warranty from Acura and Honda, if it is defective. If it has been damaged by outside forces, you have to unbolt the seat, 4-14 mm bolts, also unplugging the wires under the seat. The seat belt is held in with 1 14 mm bolt, be careful lifting the seat out the door. I usually remove the plastic door sill so it doesn't get scratched. On some cars I can lie the seat on its side inside the car to do the work.
How do i turn of my airbags on acura rsx
I presume you mean SRS light. You need to find out what the code is. Seat belt buckle failure is common. Honda warranties seat belts for life, so if that's the failure, it is free.
Seat belts locked up on VW Polo 2006 model - had accident but air bags did not deploy
Any seat belt problem is covered under a warranty program. However if vehicle was in a wreck this may have triggered the lock up feature of the seat belt.
You will need new seat belts.
How to replace drivers side airbag
buy the FSM and read it. its all there , every word.
or login to alldata.com and read the SRS section.
and the big warning one every page..
DEFEAT, this system before working near it.
this system has its own scan tool, so tell me, how'd work with out that
its just wire and models !
6helpful
Low beam light bulb issue rsx type s acura 05-06
The three prong base is just the bulb holder.
Here is an excellent tutorial on how to change the build:
http://forums.clubrsx.com/showthread.php?t=303640&highlight=change+bulb
Just did an oil change but cannot find the reset button on a acura rsx
I can tell you that on a 2003 you put the key in the ignition and press and hold the odometer reset. While holding the odometer reset turn the key to accessory. After a second or 2 the light should go off and then release the reset button.
Seat belt locked out
Seat belts are warranty items for life from Honda.
Top Acura Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Acura Expert? Answer questions, earn points and help others
