NetTV DTV-29XF3 29" TV Logo
Question about NetTV DTV-29XF3 29" TV
My LG Super Slim 29"
Posted by watolle on
  • 1 more comment
  • Anonymous Feb 09, 2013
    My LG Super Slim 29" is not start could you help me?
    When I Test by volt meter at 195 v it had only about 55v .but is not working
  • francoise cleofas
    francoise cleofas Feb 10, 2013
    you must check the primary capacitor at the power supply section using a capacitance checker which get bad.
Todd Hill
    Sergeant:
    Champion:
  • 433 Answers
You don't have a deflection yoke problem, you have a pin cushion problem. Check the pin cushion transistor.
Posted on Nov 14, 2011
2answers
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs Ā· 22 Inch to 29 Inch Class TVs Ā· 32 Inch to 39 Inch Class TVs Ā· 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 • Televison & Video
2answers
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 • LG 47LS4500
How to get an undistorted picture without cropping. This is an Olevia, and it is not listed below.
I assume you have a wide screen tv? most TV show are broadcast in a square (4:3) format, on a wide screen television the screen is rectangular, so to fit the square picture on the rectangle screen you have to either crop the top and bottom, or stretch and distort the image. the only real solutions are either to watch everything in the 4:3 format (leaving the sides of your screen blank), or subscribe to HD which will broadcast most programs in a wide screen format with out distortion.
My 29" LG golden eye T.v is view pictures in concave
Thyere is a fault in the horizontal stage or supply, I suggest Horizontal, if electronically minded check capacitors around the HO stage, could also be a ceramic cap....Phil
5helpful
NEW 37" LG TV & PEOPLE LOOK FAT & SUV'S LOOK LIKE STATION WAGONS
Go to your TV settings and change the "Zoom" function (not sure if LG has same terminology as my Sony) - you can flip through different options until you get to the setup that does not "stretch" the picture to fit the screen - if certain shows are filmed in 4:3 format (or square), they will need to be displayed with two black bars on either side (letterbox) on a widescreen set so the image is not distorted or stretched.
By the picture that you have supplied with the question you have a rear projection tv. The problem you are describing sounds like you have had the convergence module in your tv fail. Depending on the age and make of the tv, the repair costs ( if out of warranty ) can be prohibitive. The convergence module on rear projection tv's not only is in charge of bringing the 3 different color images together into a watchable picture but also handles the east west correction ( concave / convex aspect to the picture or lack there of ).
My monitor is monkeying around
The problem is with your Memory IC. Replace it.
3answers
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Open Questions:
See all NetTV DTV-29XF3 29" TV Questions
Top NetTV Televison & Video Experts
Marvin
Marvin
Are you a NetTV Televison and Video Expert? Answer questions, earn points and help others
