Question about Watches
I have a Nautica Challenge NMX-100 that I need to find replacement screws for. These 8 tiny fillips head screws are located on the back of the metal watch casing. Can't find them anywhere on line or in town. I need to know what size these screws are. Thank you.
Posted by andywilli506 on
  • Anonymous Mar 22, 2014
    want manual
mdoher12
    New Friend:
  • 4 Answers
You could take your watch to a local jeweler who would most likely have screws and probably give them to you for free. Or you could send a letter to the Nautica customer service department to request screws for your specific watch model. Here is the address. TG Service Center, PO BOX 2802 North Little Rock, AR 72115. This department routinely fixes Nautica watches and should most likely be able to send you screws for the back of your watch. If neither of those options work you could try buying the screws online on a website like this http://www.ofrei.com/page586.html If you are unsure you will find the proper sized screws, try taking a screw out and accurately measuring it. Google the some type of online screw warehouse, screw seller, or watch part store, and search for screws with the exact measurements of the screws on your model.
Posted on Jul 22, 2011
N19512 nautica watch
GO TOEBAY.COM AND SEARCH NAUTICA REPLACEMENT BAND 100% ORIGINAL
Dec 25, 2012 | Nautica Watches
How to replace second battery in lorus z011 watch
I just replaced this battery myself, it wasn't easy, but is doable. First, you will need some tweezers, a tiny phillips, and a tiny flat blade screwdriver. Totally at your own risk!
- Remove the 4 small screws on the back of the watch
- You will see a large battery under a metal clamp, this is for the back light. Remove the two phillips screws securing the clamp, and put that aside with the battery and screws. The clamp also has a metal flap on the side that acts as part of the mechanism for the back light button.
- You will now see the second battery hiding under the circuit board, it will have a small black circular rubber sticker on it. Remove the third remaining screw (very near the right hand one you have already removed) to take off the circuit board. It is clicked down slightly onto two lugs, so prise carefully at the left and right to free it
- At this point be very careful not to tip the watch upside down. There are two very small brass springs which make contact with the very top and bottom underneath of the circuit board, which now they are removed could easy fall out
- Under the circuit board is a plastic sheet, remove carefully with tweezers
- You are nearly there! There are three flat head screws, I got away with just undoing the two nearest the battery, and the third I loosened off enough to carefully lift the metal up to get the battery out
- Carefully remove black sticker, and put it on the replacement battery instead, and now reverse the entire process. Getting the metal clamp back on to secure the battery, and put the screws back is really quite fiddly, make sure it is help down properly
- Make sure before you put the circuit board back, that the two brass springs are in place. When putting the metal clamp over the larger battery, make sure the metal flap that is pushed by the backlight button is in place properly.
Avoid touching anything inside the watch with fingers, use tweezers to remove screws and parts, and make sure you keep track of which screws went where. Good luck!
Jan 26, 2012 | Lorus Watches
What tools do i need to repair the band on my nautica steel 10071G watch?
GO TO EBAY AND SEARCH:
"NAUTICA REPLACEMENT BAND 100% ORIGINAL"
Sep 19, 2011 | Nautica N07518L Wrist Watch
What its a number to battery for nautica watch n09530?
Best way to make sure you buy the correct battery is to open the back and check the # on the battery. You may need a magnifier to see the # clearly. If your changing it yourself be sure to use a blunt, non-metallic tool to remove and replace the battery.
Mar 08, 2011 | Nautica N09530 Watch for Men
Can i buy a replacement metal wrist band for this watch? Model n19510
The only place you can get a replacement Nautica band is through Nautica. Here is a link to get you where you need to be:
http://www.nauticawatches.com/service
Best of luck to you.
Aug 11, 2010 | Nautica Nst Chronograph Chrono Black with...
No alarm, chime, or beep battery is hew, all displays are working, just no sound.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 22, 2010 | Timex T5E231 Ironman Triathlon 100 Lap...
Nautica Compass watch
Any local watch repair shop will fix this.
Jan 10, 2010 | Nautica Compass Chrono Date Leather Set...
Alarm Malfunction.
remove the band and the back of the watch, rotate the back 180 degrees and replace. The alarm should sound again.
Dec 10, 2008 | Timex Sports Ironman Triathlon 100-Lap...
Where can I get a wristband for Nautica 14504G?
CALLANEN INTERNATIONAL
ATTN: SERVICE CENTER
145 WOODWARD AVENUE
NORWALK, CT 06854
Phone: 1 800 248 3775 Fax: 1 203 855 0657
Nov 13, 2008 | Nautica N07518L Wrist Watch
Watches Logo
173 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
