Check the wires at the amp. Make sure that the wires are neatly bundled and clean cut when connecting them, a stray wire may be going under one of the connections from the battery input to the ground input of the amp, there for causing a direct short and blowing the fuse. I am assuming you mean that the amp's fuse is blowing. Get yourself a test light and test the wires for power. battery power?(12V) is always on and remote power(12V) comes on only when the radio is on(it should be the blue wire in color). Then make sure you have a very good ground, I always use the seat belt bolt or car seat bolt(direct to chassis). If you checked all these steps with no luck then the culprit may be your amp.
