A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Unless you are a qualified audio service technician, you should refer repair of this unit to an authorized Behringer service depot. The capacitors you refer to can store lethal amounts of electrical charge. Also, Behringer service manuals and schematics are notoriously difficult to get.
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
it is not remote problem
please check the following
1 speaker or its wire for loose
2 check supply to sound section
3 check loose contact or loose part or print.
4 check for loose connector
5 check audio ic
6 check for signal to sound section ic is coming.
hope this will help.
