Panasonic NN-T994SF Microwave Oven Logo
Posted on Jul 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turntable will not turn. - Panasonic NN-T994SF Microwave Oven
brismac
Level 2:
New Friend:
  • Expert 93 Answers
  • Posted on Jul 21, 2011
brismac
Expert
Level 2:
New Friend:
Answers
93
Questions
0
Helped
42723
Points
247
1) a very likely thing is that fluids have gone down the stem of the drive and it has now seized the motor.
2) the most usual things are a fault in the bushes etc. This site would be a good place to be looking for advice in that respect. http://www.partselect.com/microwave+carousel-wont-turn+repair.htm
1helpful
GE Microwave turntable turns when off and doesn't turn when on.
It needs professional service. There is a switch, or a module board that is giving wrong info to the turntable motor.
1helpful
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
1helpful
Phillips whirlpool microwave turntable not turning
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
1helpful
2answers
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Turntable won't turn
The turntable probably isn't on the spinny thing and that is what makes it turn- try lifting it up and putting it back on.
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
I have a gold star above range microwave, mvh1615ww, man. in Sept. 2006, the turntable is not turning, any quick fixes?
Try the TURNTABLE ON/OFF pad. Touch this pad to turn off the turntable or turn it back on. “OFF” will appear in the display when the turntable is turned off.
Do you mean MV1615?
If so, we have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
You may need a new turntable motor or coupler.
1helpful
Turntable does not work
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
