Question about Kenwood KVT-715DVD Car DVD Player
I have a kvt715dvd and every time i turn my car off and turn it back on it asks for password and all audio settings are reset. How do i stop my audio settings from resetting? i dont want to set my audio every time i turn my car on.
Posted by blusamoa on
the pot
    Sergeant:
  • 188 Answers
Dude you need find the memory wire which is either a yellow or red wire that is connected directly to the battery supply if its not connected then thats your problem, look up the manual or google the wiring harness colour codes to be definate that you have the right wire
Posted on Jul 21, 2011
Belkin wireless stopped working - when re submitting WEP password, just says timed out
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 13, 2013 | Belkin Computers & Internet
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
My wifi is asking for apassword and i never put a password on it. how do i get around it?
If you did not set the password, then reset it back to default:
Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds.
If you want to configure the router:
Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 27, 2010 | Linksys WRT120N Router
How do i turn on brian the brain
Turning On Brian for the First Time:
This operation must be done by an adult:
Hold down the “Q” key and push the RESET button at the same time. First, release the RESET button,
and then release the “Q” button after 2 seconds.
Enter Your Name:
Brian’s your new best buddy - he will ask you for your name. Type it in using the keypad controller. If
he is familiar with your name, he will call you by your name. If not, he’ll call you pal, buddy or dude.
Password Set Up:
Brian is a password protected to make sure that it is really you that is interacting with him. He’ll guide
you through setting up your secret password - think of a word that is easy for you to remember. To
make it easy for you to remember and for Brian to understand, use a word with just one syllable like
“SMART” or “BLUE”. Make sure you are by yourself in a quiet room so no one else can hear you tell
Brian your password!
When Brian asks you to say your password, hold the keypad about 12”inches [30cm] from you and
speak clearly but in a normal voice. Brian will ask you to repeat your password.
Brian will also ask you to type in your password. He will then ask you to type it in again for
confirmation. If you want, you can type in a password that’s different from the one you spoke
to Brian - he’ll remember both. Your typed-in password must be shorter than 16 letters.
Password Reset:
If you have forgotten your password and want to reset it, enter the following code when Brian
is asking who you are: Hold down the “Q”, “SPACE/SKIP” and “P” buttons at the same time.
Time and Date Set Up:
Brian will tell you how to set up the correct time and date.
You can get the manual on link below.
http://www.robotsandcomputers.com/robots/manuals/BrianTheBrain.pdf
Good luck and please rate 4 thumbs for free answer.
Mar 03, 2010 | Hammacher Schlemmer Brian The Brain
Password
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
It ask me enter code. But I lost My security code. Model Number is ZCD-3501AK Make is Zylux Serial No.: HM04040666
Defore starting try default password : 1369
Press the direction keys UP,DOWN to select Default. If Default is selected, press enter key to reset the unit to factory
settings. If you reset this unit, the memorized settings such as Password, Color Settings, Audio Settings will be changed
to Factory Settings.
AFter password getting resetted. try Default password is 1369
Regards
RNJ VINOD KUMAR
Sep 17, 2009 | Car Audio & Video
I want to find out the reset password to my shinco rc 200 dvd
Turn the dvd player off. Then hold the Stop button and turn the dvd player back on. It should work.
Dec 22, 2008 | Televison & Video
Parental Controls feature
Hey Aurora, After you put your password in, go back and change the password using blanks spaces. Then it should reset to 'parental control off'. Let me know if this works. Some Sanyo models are different to reset.
Jul 21, 2007 | Sanyo Vizon LCD-15A2 Television
Kenwood KVT-715DVD Car DVD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
