Cameras Logo
Question about Fuji Cameras
Cant put pics onto my memory card for my camera help?
Posted by whitney_klat on
ZJ Limited
  • 17,970 Answers
Take off the SD card and connected the camera at pc, then you can read the pics in the internal memory... first copy/paste in a folder (confirm) and next delete from internal memory.
Posted on Jul 21, 2011
Anonymous
  • 489 Answers
You can't transfer pictures from internal memory to a memory card, sorry. You need a USB cable to connect the camera to your computer then you can transfer the pictures to the computer.
Hope this helps.
Thomas
5 Related Answers
Anonymous
SOURCE: Transferring images on camera memery onto memory card.
I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
1. Put an SD card in the camera. Will not work otherwise
2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
Posted on May 13, 2008
Anonymous
  • 16 Answers
SOURCE: Fujifilm FinePix Z20fd protected card??
The memory card should have a little switch on it, try it in the other position. It is a safety lock to stop it getting wiped.
Posted on Feb 13, 2009
Anonymous
  • 423 Answers
SOURCE: Need to put Pictures from Camera onto Memory Card
Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
Posted on Feb 17, 2009
Anonymous
  • 34 Answers
SOURCE: move pics from internal memory onto a Sim card
Press "Menu".
In the menu go to the symbol (wrench and camera).
Go to the "image storage" and choose "Internal".
Leave the menu. Press "preview". You'll see only pic's from the internal memory.
Press "Menu" ... "Copy" and choose all.
After that go back to "image storage" and choose "Auto"
Posted on Jun 07, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Olympus FE-370
See page 34 of the manual (available for free download from Olympus below).
http://www.olympusamerica.com/files/FE-370_X-880_C-575_Instruction_Manual_EN.pdf
Or in short, select the "Setup" (tools) menu, and then select "Backup". You'll need to have the memory card installed for the transfer.
Posted on Jul 04, 2009
Is it possible to transfer pictures from the camera memory onto a card? I have taken pics and then put the card into the camera and want to put the pics on that card
yeah you just pick the picture you want to send to memory card. you click on options go on to move and click on memory card or external memory.
goodluck:)
please rate this solution...
Jun 08, 2010 • Cameras
2helpful
I cant get my pics to go onto the memory card they seem to be going to the camera itself it will only hold 6 pics and I have a 4GB CARD. hOW DO i FIX THIS PROBLEM?
The problem is you are using a SDHC SD card (>2gb). They are not compatible with the a550. You need a 2gb or smaller standard SD card for it to recognise in the camera. Th epictures will then save onto it no problem.
3helpful
Photos onto my computer pc
Select "Backup" from the Setup menu to copy pictures from the internal memory to a memory card. Then you can transfer them from the memory card to your computer as usual.
1helpful
Olympus FE-370 I have 10 pictures on the camera (tok pics without realising there was no card inside!), but I cant seem to save them to the memory card - I have lost the lead for the camera. Is there...
2answers
Dont know how to get pics out internal memory
Actually, you can do it without the cable.
You need to have the card inside your camera with at least ONE picture. Hit play. Press menu. Scroll down until you see COPY and then choose "Internal to SD Card" Hit All Frames. Hit OK. Done.
Cheers,
V+
How do I copy internal memory pictures onto a memory card?
can't. move them to your computer then delete the pic through the camera then put the memory card in and the camera will automaticly store all new pic to the external memory card
1helpful
2answers
Fuji FinePix E550
format by going to option while in shot pic mode , first press ok then option, set-up go down to format and after should be working.
I cant get my software to upload...?
use a memory card reader for your pro duo card-generic to computer plug and play no software and will download pics easy
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 • Cameras
Top Fuji Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve Nordquist
Steve Nordquist
Are you a Fuji Camera Expert? Answer questions, earn points and help others
