Vacuums Logo
Posted on Jul 21, 2011
My tv Sankey remote control does not work. I have a RCA universal remote control but I need the code number for programing. Can you help me. Thank you.-
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
955
Points
My sankey television is locked what code can i used to get it unlocked
I have a rca universial remote control and I lost the manual and cant program it for my toshiba television I need the code and directions how to program it
Not knowing the code, you'll have to do it using the Automatic Code Search method.
1. Turn the TV ON manually.
2. Press and release the TV button on your remote. The illuminated ON-OFF button will turn on and stay on.
3. Press and hold both the TV and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
4. Release both buttons after the ON-OFF button turns back on. The button should remain on.
5. Press and release the PLAY button. You may have to do it several times. Be patient.
If the TV does not respond after five seconds, continue to press and release the PLAY button every five seconds until the TV turns off.
6. Just to check the code is right, after the TV turns off, press and release the REVERSE button then wait to see if the TV turns on again.
If that works, you've got it!
Press and release the STOP button to save the new code.
May 24, 2011 • Vacuums
Need codes for my rca remote, model rcu404n to operate my sony tuner
Go to a computer store and buy a universal remote, they are quite reasonable now, and use that instead.
Apr 25, 2011 • Vacuums
Cant get my rca remote to work on ,my sharp tv i need the code for sharp tv the model onmy remote is rcr311w
Not really sure what to do here, whether or not its a universal remote you are referring to. The attached is a link for almost any users manual for anything electronic. Hope it will help you find the users manual with the correct code. http://www.retrevo.com/support/HP-m8150-Desktops-manual/id/3167ag902/t/2/
Mar 21, 2011 • Vacuums
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 • Vacuums
I lost my codes for my universal remote i need answers asap!
Hi Coourtneeylyn,
You can find the code sheets for the GE Remotes made by JASCO Products at the following website:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Please let me know if you should have any further questions!
Blessings,
GeekyGuru
Jan 03, 2011 • Vacuums
I HAVE A PANASONIC TV W/ A PHILIPS UNIVERSAL SRC306/27 REMOTE. I NEED THE CODES FOR THE REMOTE.
I suggest you check with the manufacturer for that particular remote. If they are available they will be the only place you can find those codes. Or find the book that came with the remote
Mar 29, 2010 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
