I just ordered a D-Link for internet access. I have a laptop that is wifi capable, has an Ethernet connection port and modem. Do I need to have an internet connection already established through a desk top model to use it?
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
It's a wireless router, so you may not need to use a port at all.
You can connect to any of the ports numbered 1 through 4. The yellow Internet port should connect to your outside network. (Cable modem or router or Ethernet port from your Internet service provider.)
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
yes 4 sure......i am currently using internet connection from Ethernet port...and i am broadcasting my internet connection to my friends using a router connected to my PC.
So you can connect both of them simultaneously...enjoy..!!
first check with the ISP if any DNS server settings or proxy settins are required(but i think you can alternatively connect your laptops these may have ben already set on the laptops but just in case)
now if your ISP accepts you to have more than one connection from the same link then you can connect the connect the cable from the modem to the INTERNET/WAN areas and you can connect the ethernet cables in the ports marked 1,2,3,4
here check that if you are only etting the link on the computer connected to port1 and no connection on the others then make a small adjustment disconnect the cable from WAN/Internet port and connect it to the Port1 and the computers to 2,3,4
now that you are saying that u r not interested in the wifi so it is advisable that you go to the home page of the router and from there to the wireless page and disable the wireless broadcast of the router for safety purposes
this can be changed any number of times back and forth
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router: A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
