Question about Apple iPhone Smartphone
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off works great...
Posted by mmacko612 on
  • Jaylin Owens Jun 26, 2013
    The same thing happened to me except i didn't get the glass fixed
Christopher Lozada
  • 1,140 Answers
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Posted on Jul 21, 2011
Wont slide unlock
probably the touchscreen just broke on the bottom part after a while
Jun 26, 2013 | Apple iPhone 3G
My iphone 3g 8gb seems frozen, on my main screen it says slide to unlock, well it won't slide to unlock, ive turned it on and off again and done the reset thing but no joy at all, does this mean my...
try the new update that just came out today , sync your phone in itunes and then install the new update on the ios software . hopefully this works
May 05, 2011 | Apple Cell Phones
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
Bottom half of iphone 3g screen not working?
Go to http://custompod.co.uk/ and email them for more information
They will also give you a price for the work, and you wont have to remove the jailbreak
Jun 05, 2010 | Apple iPhone 3G Black Smartphone
IPhone slider won't slide all the way across
I'm having the same issue, have you found any solution?
Apr 30, 2010 | Apple iPhone 3G
Lower Half of my touchscreen on iphone does not work!
seems you have iphone 2g phone. your touch screen problem and needs to be replace.
Apr 28, 2010 | Cell Phones
I dropped my iphone on the floor and there is sound coming from it but the screen is completely black, Will i have to buy a new screen?
Hi!
If your screen is not having a crack on it then there is a possibility that it can work again.
But if it has a crack then you need to buy a new screen.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 06, 2010 | Apple iPhone 3G Black Smartphone
I dropped my iphone and now the unlock slide doesnt work
It looks like you need a new LCD/digitizer which you canreplace yourself. Here's a guide on how to disassemble an iPhone. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party iPhone Repair Services.
Mar 18, 2009 | BoxWave Corporation Apple iPhone 2G...
IPhone touch screen not working
I have the same exact problem. I dropped mine, and it landed half on concrete, half on a piece of foam board, and when I got to shut mine off, it will slide to power off, but will not slide to do anything else. Everything works perfectly fine, people calling me, texting me, nothing is broken or cracked, I can't even unlock mine, it's stuck and it's making me very upset! I want an answer as to what I can do and or can't do.
Jan 28, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
631 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
