Remove the lense, or the film if you're willing to waste it, and check to be sure the shutter blades aren't damaged. It'll be fairly evident if they are. If they are, the camera is pretty much now a paperweight. I hate to tell you that - but shutter replacements are VERY expensive and parts for most of these models no longer available from Nikon.
If that is not the issue, set the mode dial to M and try to take a shot. If that also doesn't work, either the batteries are exhausted or there is an internal issue in the camera. At this point, try new batteries. If that also gets you nowhere, you'll need to seek a reputable service tech, either through Nikon directly, locally if you can find one, or online/mail-order. If you have to go mail-order/online I'd recommend KEH Camera out of Atlanta, GA. They are very reasonable, have decent turn around, and do good work - but expect at least 1 month without your camera.
In M(anual) mode, be sure the lense is also set to M, via the switch on the front of the camera near the lense mount. You're not worrying about the quality of the image, only if the camera will take one. In manual mode, the light meter and other functions will have NO bearing on anything the camera does or doesn't do. At this point the meter reads out only for your information for you to set the settings yourself. The batteries do everything else - firing the shutter, driving the motor, etc.
