Question about Canon PIXMA MP495 InkJet Printer
Alarm light is on and it gives an error code 5200 when i try to print from my cannon MP 495
Posted by tiltonfamily on
JDTec
  • Canon Master
  • 4,338 Answers
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 20, 2011
I have an Canon MP 830 with error 5200. What can I do to fix it myself?
The error 5200 is either print head overheated or the logic board is faulty.
If it overheated, there might be burn marks on it somewhere or some distortion due to excessive heat.
Nov 29, 2013 | Canon PIXMA MP830 All-In-One InkJet...
HI, We have a purchase a Canon mp-258 all in one printer now we are facing a problem to not getting a print out as well as copies. printer shows a ERROR- 5200 CODE so pls give me the solution asap....
this is error for printer head temperature rise error. Possiblle cause can be in faulty ink cartridge.
Try to reinstall the ink or install new one.
If the printer is new and under warranty, take it to the service centar for replacement/repair under warranty.
Hope that helps!
Aug 29, 2011 | Canon Office Equipment & Supplies
Cannon pxima MP 357 no printing & search for e 5200 error to the manual user guide
error 5200 means the printer is unable to detect ink cartridge.
I do suggest you remove the ink cartridges from your printer. Examine the surface contact to where the terminals inside the printer touches. Clean this surface with clothe moistened with alcohol.
After that reinstall the printer and see if the printers successfully detect the cartridges..
Press the stop / reset or the cancel / resume button (the button with inverted triangle enclosed in a circle) hold it for about 5 seconds until the printer self restart.
ALPUG
If this will help, please give my answer some ratings!
Mar 25, 2011 | Computers & Internet
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
My cannon printer alarm light stays on a i cant print whats wrong with it?mp 160
Try to push consistently the black copy button, then color copy button.If this not help check the error code on the LCD.It's "E" and some number.Check that number in this site.
Oct 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5200...
5200 is an abnormal temp. rise in the printhead. Not related to your other problems, but you need a new printhead. QY6-0063-000. Around $50.00
Apr 15, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA MP495 InkJet Printer Logo
657 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
