Question about Bosch Dishwashers
Dishwasher will not fill have changed the inlet valve but still not filling.
  • 4,323 Answers
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jul 21, 2011
6ya staff
SOURCE:
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: Dishwasher will not fill
EE,
The most likely culprit in a "no fill" scenario (especially after you've replaced the valve) is the Overflow preventer. It's designed to kill power to the valve if the water level gets too high. It does this by floating up as the water level rises.
Open the dishwasher door and remove the lower rack. You'll see it in the tub on the left side (the round thing that looks like a little hat). If it's stuck in the up (overflow) position, you won't get water. Raise and lower this device a few times... you should hear the "click click click" of the kill switch. Now just make sure it's in full down (ready for water) position and fire up the dishwasher. You should get water now.
If this helped, please rate this solution as "FixYa". BUT if this didn't fix the problem, don't rate it just yet. Write back and we'll go a little deeper into a diagnosis, OK?
SG
Posted on May 01, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: noisy kitchenaid dishwasher during filling
Fill valve replacement should be fairly simple. Most dishwashers are constructed in a similar manner, so although these steps are generic, it should lead you in the right direction: 1. Remove the lower kick panel right below the dishwasher door. The fill valve should be located in the front of the dishwasher on the left hand side. 2. Turn off the water supply line. 3. Turn off the circuit breaker to the dishwasher or unplug the unit as necessary to secure power. 4. Carefully remove the two wire connectors going to the fill valve solenoid. These wires are delicate, so be careful with them. 5. Leave the fill valve attached to the mounting plate in order to loosen the supply line. Once you have the supply line loosened you can remove the valve from the mounting plate by removing either one or two screws. 6. With the supply line disconnected, wires removed and the valve removed from the mounting plate, you can now remove the secondary water line that goes into the wash tub. It is usually behind the valve and easier to access if you can pull the valve out far enough the reach it. 7. Make sure you put teflon on all your threads BEFORE you re-install. 8. Installation is in the reverse of what I just explained to you. You should not have to remove the dishwasher from under the counter, but you can if it makes access easier. It's that easy. Just make sure you check your water lines for leaks BEFORE re-installing the kick plate. And, make sure you reconnect the wires properly. Good luck. I hope this helps you.
Posted on Jul 10, 2007
Anonymous
SOURCE: Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Posted on Dec 13, 2008
Anonymous
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
roberta3fan
  • 574 Answers
SOURCE: mACHINE WILL NOT FILL, HOW DO i CHANGE INLET VALVE
most inlet valves are near the front of the washer. The kick panel at the front of the dishwasher should have several screws holding it, take those out ant the kick plate should come off where you can get to the valve. Look under the sink cabinet and you should see two vertical water lines and one horizontal line. The one horizontal line runs through the side of the cabinet to the dishwasher it should have a shut off valve on it close the valve and that will cut off the water going to the dishwasher. Have several towels ready because there will be water left in the line. Either unplug the dishwasher or turn off the breaker for the dishwasher before working on the valve Place a towel around the area of the inlet valve and disconnect the line coming to the valve. Should be a couple of screws holding the valve to the washer. Disconnect the electrical connections and remember where they go. Take valve out and reverse the procedure for installation.
Posted on Jan 07, 2010
Testimonial: "very helpfull, but ithink the valve is at the rear of my machine"
Dishwasher won't fill with water
Hi
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwasher not filling up with water
Hi
Daniel
Aug 15, 2011 | Viking 24 in. Professional Series VUD040...
Hello. My dishwasher (Miele G 579 SC) does not fill water enough. When filling is done I must fill manually with a bucket to get water to a sufficient level. What might be the problem? Kind regards...
Hi
Daniel
Aug 05, 2011 | Miele Dishwashers
Water is not filling up.
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher is not working will not fill with water
Hi
Daniel
Jul 20, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
Bosch dishwasher does not fill with water
Hi
Daniel
Jul 19, 2011 | Bosch Dishwashers
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
Dishwashers Logo
436 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
