Question about Vtech Tote n Go Laptop Plus
Vtech thomas laptop battery compartment cover has been misplaced...where i can find a replacement part for the same?
Posted by aroona_iyer on
2 Related Answers
Ironfist109
Iron
  • 3018 Answers
SOURCE: I have a Vtech Thomas
Well that won't do will it. If you go to this site https://www.vtechkids.com/cart.cfm?productNumber=1289 this is the part you need for $1.50usd. The company is in Illinois. You might see if you can take a screw and self tap it from the battery cover into the unit a bit to keep the little ones from getting to curious.
Regards, Tony
Posted on Apr 14, 2011
Anonymous
  • 13 Answers
SOURCE: missing the battery cover for vtech reader
you can buy one directly from vtech:
http://www.vtechkids.com/support/replacement_parts/
Hope that helps
Posted on Jan 20, 2012
How to activate a vtech phone
Instructions
    • 1Remove the battery cover from the back of the phone. Most models have a door that slides downward to reveal the battery compartment.
    • 2 Install the battery by inserting the connector on the battery wires over the pins in the handset battery compartment. The connector will only go on one way.
    • 3 Insert the battery pack into the compartment and replace the battery cover.
    • 4 Charge the phone by sitting it in the charger for a minimum of 16 hours on the first charge.
    • 5 Place the fully-charged phone onto the cradle of the base unit and wait for the display to show "PRESS FIND HNDST 4 SEC ON BASE." If the message does not come up, lift the phone off the base and put it back in the cradle.
    • 6 Press and hold the "FIND HANDSET" button on the base unit for approximately four seconds. The display on the phone will change to "PLEASE WAIT," then "HANDSET X REGISTERED."
    • 7 Test the phone by making a call.
2helpful
I bought a thomas engine it has 2005 Gullane (Thomas) Limited. Replaced the batteries but it still doesn't work it has a small hole on the left side top that has a drop of water (I think it is for wat
Unscrew the screw under Annie, then pull on the top part of Annie to reveal another section where more batteries go. put water in the hole on top of Thomas, not the funnel, but there's another small hole on the top of Thomas. Now Thomas will puff steam! You are lucky to have found this train, he is super fast and very unique because he puffs the steam! we have one, unfortunately my youngest son broke the chassis that connects Thomas and Annie, so it no longer works properly. You will need a dropper to put the water in Thomas.
1helpful
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
1helpful
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • 0helpful
    How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    How to set
    Hello
    2answers
    How do i reset the bios password on a compaq presario756 nr notebook i lost all my info and am havein trouble unlockin my bios password i for got
    remove both batteries, unplug the power leave it for about 60 seconds, put the power back and on then try to enter bios
    Battery instolation
    mcdevito75 here, I believe the battery--ies go in 1 of the wheels, try looking for a cover or squeeze 1 of the wheels for cover to pop off.
    Toy can't work after changing battery
    Make sure that ALL the batteries are good, right size and voltage and are the right way around in the battery compartment.
    Vtech Tote n Go Laptop Plus Logo
    Top Vtech Toys Experts
    tina gallow
    ADMIN Canada
    ADMIN Canada
    ray gallant
    Are you a Vtech Toy Expert? Answer questions, earn points and help others
