Question about Samsung RM255LASH Side by Side Refrigerator
Teardown for restricted defrost drain - Samsung RM255LASH Side by Side Refrigerator
Posted by davesapl on
ImJustAvg
  • 2,006 Answers
I have always had good luck with a guitar string and a hot air gun (or a hair dryer on high) to clear a restricted defrost drain. Just heat up the wire slightly and run it down the drain. And then blow hot air down the drain to melt any frost/ice buildup.
Posted on Jul 20, 2011
I have a small amount of water appearing on the floor, on the right side under the freezer drawer. I do not see any water under the fridg. I've also found ice in the freezer on the right side. What might...
It appears you may have a blocked or frozen defrost drain. As the repair involves a complete teardown of the freezer compartment, you may want to contact a qualified Samsung technician to make this inexpensive repair.
Jun 28, 2014 | Samsung RF265AA Bottom Freezer French Door...
Drain Pan overflowing and water is leaking in refrigerator I can see drip pan overflowing but I do not know how to get to it
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Mar 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
My GE fridge is leaking water on the freezer side
This would be due to the defrost drain being clogged. The automatic defrost cycle melts the frost on the evaporator every few hours and the water from that is suppose to flow down a drain tube, if the drain becomes restricted the water will leak out the freezer door. Here is a link to some instructions I put together on how to clean it out.
Defrost Drain Cleaning
Jul 18, 2010 | GE Refrigerators
The bottom 2 drawers fill with water. To include the bottom of the fridge. I thaught it was the ice maker not working properly so I shut the water off to the ice maker and it still happens. I have noticed...
This is due to the defrost drain being restricted. Every 8 hours or so the defrost cycle turns on automatically to rid the cooling coil of frost. The water from this cycle is suppose to drip into a pan under the coils and down a drain tube. If the drain gets restricted then the water will run down into the bottom.
I have put together some instructions on solving this. Follow this link and let me know if you have questions. If you have trouble send me the complete model number from the tag on the frig and I can get you details for your specific model.
Drain Problems
Jun 20, 2010 | Refrigerators
Water dripping from freezer area down in refrigerator water collecting under crisper drawer.
This is most likely due to the defrost drain being restricted, see the link below and let me know if it helps.
Defrost Drain
May 20, 2010 | Refrigerators
Refrig
Defrost cycles normally are timed for 8 or 12 hour cycles. This would be normal. However the drain system on your freezer section is plugged. You have to defrost it and check the drain under the coil where you seen the heater on. Make sure it is not restricted from paper or Plastic wrap. Under the refrigerator back is the drain hose that drains into the drain pan. Check it also and make sure it is clear.
Jun 06, 2008 | Frigidaire FRS26ZSG
Defrost problem
Drain line in the back of the refrigerator is restricted in some way . it may be plugged near the drain collecting pan air trap or loop.
May 18, 2008 | Frigidaire FRT18B4A Top Freezer...
REFRIGERATOR dRAIN stopped up
SOME REFRIGERATORS HAVE A CUP IN THE BACK OF THE FRESH FOOD COMPARTMENT THAT CATCHES THE WATER AS IT COMES FROM THE FREEZER AND SENDS IT DOWN THE DRAIN TUBE INTO THE DRAIN PAN. IF THE DRAIN TUBE OR CUP GETS A RESTRICTION IN IT, IT WILL OVERFLOW AND BRING WATER INTO THE REFRIGERATOR. CHECK THE CUP AND DRAIN TUBE FOR RESTRICTION.
SOME REFRIGERATORS HAVE THE DRAIN TUBE BUILTIN TO THE WALLS OF THE REFRIGERATOR, BUT THE HOLE IN THE FREEZER IS SMALL AND FREEZES OVER. WHEN THE DEFROST CYCLE COMES ON, THERE IS A BUILDUP OF ICE THAT CAUSES THE WATER TO FALL DOWN THROUGH THE AIR DUCT INTO THE FRESH FOOD COMPARTMENT. YOU WILL HAVE TO REMOVE THE BACK WALL OF THE FREEZER AND SEE IF AN ICE BUILDUP UNDER THE COILS IS PRESENT. THEN, REMOVE THE ICE, CLEAR THE DRAIN HOLE, AND SEE IF WATER WILL PASS THROUGH THE DRAIN. A FIX TO PREVENT FREEZEOVER FROM REOCCURING, IS TAKE A PIECE OF BARE COPPER WIRE AND WRAP AROUND THE DEFROST HEATER AND PASS IT DOWN THE DRAIN HOLE (ABOUT FIVE INCHES WILL DO).
WHEN THE DEFROST HEATER COMES ON, IT WILL PASS HEAT DOWN THE WIRE TO KEEP THE DRAIN HOLE FROM FREEZING UP.
Apr 16, 2008 | Refrigerators
Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Aug 15, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung RM255LASH Side by Side Refrigerator Logo
109 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
