Question about Siemens SL85A705UC 24 in. Built-in Dishwasher
There is always water left in the drain at the bottom of the dishwasher, which gets sprayed back on the dishes so now my glasses have material on them and it gets baked on in the dry cycle....
Posted by pas512 on
Daniel Scott
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Jul 21, 2011
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
The dishwasser washed not properly small pieces stick to all the dishes, plate, glasses
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 05, 2011 | LG Dishwashers
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
The dishwasher doesn't seem to be cleaning very well any more. The glasses are always dirty and the dishes just don't seem to be clean like they used to be. Does the dishwasher need some maintenance? ...
Check the following:
- The Salt Container - Found at the bottom of the Dishwasher. (If required, replenish salt)
- The spray arms (They usually get clogged at the small holes where the water should spray out of)
- Us less heat (High heat can leave white visible stains on glass)
Hope this helps :-) - J.Q
Feb 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Recently the dishes have a grainy feel and the glasses have white smears on them. Some of my kitchen cooking utensils which are made of a black material are all coming out coated in a white file
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 13, 2011 | Dishwashers
For 6 mos. now, my dishwasher has begun to leave this white filmy, cloudy residue on all my dishes. It has ruined calaphon utensils and glasses I have had for 14 years. The detergent has always been the...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Hope this helps......
Daniel
Feb 02, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishes and glasses not clean, seems like spray bars not turning water seems plenty ,no clogged filters
Hi
Daniel
Dec 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Jan 25, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher just doesnt get dishes clean anymore. some food left on dishes. there is always water pooled in bottom of dishwasher, but I've cleaned it out well at the bottom
Check your vacuum breaker. Its some times mounted up on the back of your sink. If it gets stopped up it will cause your dish washer to not drain or clean properly. Good luck.
Aug 30, 2009 | Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Siemens SL85A705UC 24 in. Built-in Dishwasher Logo
551 people viewed this question
Top Siemens Dishwashers Experts
Mike
aliasger yq
ray gallant
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
