Question about Acer TravelMate C110 Tablet PC
How do i replace the internal battery - Acer TravelMate C110 Tablet PC
Posted by keith_rob657 on
Anonymous
    New Friend:
  • 72 Answers
Please click the link and refer to the manual Acer TravelMate C110 Tablet PC
Posted on Jul 20, 2011
Can you tell me why my nextbook keeps shutting off everytime i take it off the charger
Hello, Bridget -
If you have had your Nextbook for a while, the rechargeable battery may no longer be holding a charge.
Even rechargeable batteries wear out and need to be replaced.
You can probably find the right replacement battery (for your Nextbook model) to purchase through the Nextbook home page.
I have a galaxy tab 4 10.1 16gb wifi only tablet . Whe charging my battery loses power and therefore can't charge properly. What to to correct issue.
Sorry to read/hear this.
DIY approach first is to attempt replacing the battery inside your tab.
If this option fails;
Then you have to get your tablet to a qualified phone repair/service point. Have them check the internal circuit of your tab.
Something may be amiss internally with a component.
My IRULU tablet will not charge.How can I fix it? Is there an internal battery,where is it?
Either the charger or connector has a problem. There is a battery, but it is not a normal replacement item. You will find the battery behind the back cover.
Okay my sister had her tablet she turned it on and it froze at the go screen. So I pushed and held down. The power button and it turned off, and then I don't know why I pressed the reset button but it...
Do a factory reset. Remove all power including internal battery. Let the unit discharge completely. Plug into external power supply and try to start up. If it starts. shut down, put the external cord out , replace internal battery, and recharge for an hour. Now try a strat from the internal batter. If it fails, that s the problem.
My tablet wont charge it was purchased nov 2013
the internal battery has reached it's lifespan.....use power bank if you don't want to replace the internal battery..the tab will get the power from the power bank...powerbank is a recharcheable battery with usb connection than can be connected to your tab to power it up....
1helpful
2answers
MY TAB IS NOT SWITCHING ON OR GETTING CHARGED
If its still under warantee you can send it in to the manufacturer to have the battery and charging system replaced. If not it has internaly 2 gel batteries that are (with some work) replaceable. They were not designed to be replaced but can be. It has 2 snap tabs on each long end that can be opened with a flat head screw driver. If it is an older model it may also have 4 screws one under each foot pad an eye glasses screw driver can remove these. Once you get it open the batteries are two identical silver rectangles that togeather take up the majority of the internal workings. They have part numbers that can be used to order new ones from radio shack or another electronics store. I recomend sending it to the manufacurer however. The not only do great work they also wartee their repairs.
1helpful
2answers
My HP TouchPad will not charge.
Looks like the internal battery is shot. Contact HP for price for replacement of the internal battery,
1helpful
2answers
Battery wont charge
Is it a different charger? If it isn't try plugging it into a car or at home on the computer or the wall. If that doesn't work maybe getting it checked out will help.
Windows date/time does not persist across shutdowns. It must always be reset
Sounds like a CMOS battery problem, assuming the internal power battery is working fine. May have to get someone to open your tablet PC to replace the battery (cmos)
Acer TravelMate C110 Tablet PC Logo
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
